weird stuff happening
1 THING
1 THING is offline
PostPosted: Tue Jul 17, 2012 6:09 pm    Post subject: weird stuff happening Reply with quote
what do you think?
car always been rough to start, even after refurbished starter...new ground wire and hot wire on battery.....battery is a few months old and read 13.5v at rest
started car last week and ran it for 15-20 to try and recreate oil leaks, pulled back in garage and shut off
just removed dash panel and replace all fuses to start fresh....headlights, hazards, turn signals all work better after replacement
only problem now is, engine wont even start.....when key is turned, i hear one click in back right (assuming it's starter) and that's it Crying or Very sad
there's no way to short out starter by checking charge on battery? isthere? just touched sensors to respective battery poles and got reading
what in the world??
1 THING
1 THING is offline
PostPosted: Tue Jul 17, 2012 6:26 pm    Post subject: Reply with quote
im not familiar with it, i think ive found the wire/plugs in my battery area......but wasnt sure how to use them so i wrapped them in plastic to keep moisture from being introduced at any point
if there's something i need to attach to those plugs, to obtain a reading, i definitely dont have it
1 THING
1 THING is offline
PostPosted: Tue Jul 17, 2012 6:27 pm    Post subject: Reply with quote
oh well, i replied to the post that was removed?
Semper_Dad
Semper_Dad is offline
PostPosted: Tue Jul 17, 2012 6:50 pm    Post subject: Reply with quote
Yea sorry about that. Wanted to confirm my data before posting it.
The wires in the battery area which should be;
Brown
Brown/White
Red/Yellow
are part of the defunct diagnostic system. They don't need to be hooked up to anything. Used to hook up to a special VW battery no longer available.
Anyway,....I was trying to figure out which pins to short together to activate the solenoid.
74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
World 181 Registry Map: http://www.zeemaps.com/394427 Gitm registared boys!
Officially, there are only 99 181s in the world
Wildthings
Wildthings is offline
PostPosted: Tue Jul 17, 2012 11:21 pm    Post subject: Reply with quote
What happens if you jump between the male spade(s) on your solenoid and the big lug with the cables on it. That should make your starter engage, so don't run yourself over.
1 THING
1 THING is offline
PostPosted: Wed Jul 18, 2012 10:55 am    Post subject: Reply with quote
my mechanic said this had happened to him, ill re-check fuse box when i get home.....he said a particular wire can come unattached very easily, must have something to do with ignition......hopefully this is the issue!
Ron Domeck
Ron Domeck is offline
PostPosted: Wed Jul 18, 2012 2:23 pm    Post subject: Reply with quote
Next time this happen's reach for the plug on the ing. switch and wiggle it and push it up to the switch.
1 THING
1 THING is offline
PostPosted: Wed Jul 18, 2012 5:44 pm    Post subject: Reply with quote
i did happen to try that, seemed tight.......went through all wires to fuse box, tightened and replaced damaged connectors......lights are dimmer tonight than last night..........battery is dying, has to be
thanks for the tips everyone......taking this battery to Interstate tomorrow
1 THING
1 THING is offline
PostPosted: Wed Jul 18, 2012 5:48 pm    Post subject: Reply with quote
"more dim"....my kentucky comes out sometimes Laughing
Wildthings
PostPosted: Wed Jul 18, 2012 7:26 pm    Post subject: Reply with quote
If the headlights are getting dimmer while the engine is revved up you aren't getting output from your generator/alternator. Which one do you have by the way the stock generator or an alternator?
1 THING
1 THING is offline
PostPosted: Wed Jul 18, 2012 7:29 pm    Post subject: Reply with quote
no engine running, it wont even turn over...........the lights came on brighter last night than this evening, just with ignition turned to battery
1 THING
1 THING is offline
PostPosted: Wed Jul 18, 2012 7:30 pm    Post subject: Reply with quote
but i have the stock generator
Busdriver79
Busdriver79 is offline
PostPosted: Mon Jul 23, 2012 5:53 pm    Post subject: Reply with quote
When my wiring system goes south, I'm going to cut out every inch of the factory wiring and rewire the entire vehicle myself to my specifications....engine/charging system, lights, turn signals and instrument lighting....keeping it very simple and using modern mini fuses in a convenient panel under the boot lid ( front)....ignition key switch and push button starter..should take about a weekend. Very Happy
carsdlt
carsdlt is offline
PostPosted: Mon Jul 23, 2012 6:13 pm    Post subject: Reply with quote
Sounds like you may have more than 1 problem... first, you need to have a strong battery. Have it tested and/or buy a new one. Then check your connections... ground cable and starter cable... both ends...clean & tight. Now get in and turn on your lights...hit the starter. If the lights go dim while the key is in the start position and you hear nothing or just a "click" from the rear of the car, I would suspect a bad starter/ solenoid if all the grounds are good. Good luck.
DLT
Wildthings
PostPosted: Mon Jul 23, 2012 6:16 pm    Post subject: Reply with quote
Sounds like a good title for a movie about Kentucky, More Dim and Dimmer. Wink
1 THING
1 THING is offline
PostPosted: Wed Jul 25, 2012 5:14 am    Post subject: Reply with quote
^HAAAAAAAA! you're so clever Rolling Eyes Laughing
it was indeed my battery (my issue), down to 3.5v at rest the next morning, took it in for replacement, and took it out driving Very Happy
