1950split Samba Member
Posted: Sun Jul 22, 2012 2:41 pm Post subject: Deep sump cleaning |
Hi,
Maybe a silly question but how do you clean your oil sumps as you cannot see the interior very well and that the casting flashes make good traps for debris.
I've had a damage on a rod bearing and found small chips on the strainer plate. I poured acetone in the sump, shook it well and after emptying the acetone I used the compressor to blow it.
I'm not sure this is the best method an although I have a full flow set-up that should catch contamination I'm reluctant to start the freshly rebuilt engine with this sump..
Thanks for your help,
Phil |
WanderHopple Samba Member
Posted: Sun Jul 22, 2012 2:49 pm Post subject: |
I clean sumps by submersing them in my solvent tank and blowing air into it while under the solvent. {Be very careful, solvent can be blown all over the place if you do not have it completely under}
I use an air blower with a long tube on it so it will reach all the way in. _________________ Dave Hopple Classic VW
2224 E.Highland St. Suite C
Shawnee, OK 74801
1-405-275-1703 |
SRP1 Samba Member
Joined: January 06, 2007 Posts: 3912 Location: Escondido, CA
Posted: Sun Jul 22, 2012 3:03 pm Post subject: |
You have the cases apart or together?
You must pull the bottom end completely apart to remove debris and flush/brush out the oil galleys.
Don't forget your cooler and hoses will be filled with metal also, I recommend you replace it. _________________ www.srpengines.com
Bugless....... |
Posted: Sun Jul 22, 2012 3:06 pm Post subject: |
I have rebuilt the whole engine, everything was taken appart and cleaned. Now the engine is back together and I'm just left with this sump issue.
I will replace the cooler and thoroughly clean the oil lines.
Sadly I don't have a part washer. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55653 Location: Long Island, New York, USA
SamT Samba Member
Posted: Sun Jul 22, 2012 3:57 pm Post subject: |
| I wash everything but steel Parts at The car wash. |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 8507 Location: SHALIMAR ,FLORIDA
Posted: Sun Jul 22, 2012 4:27 pm Post subject: |
| the actone works good, and you can add a few small peices of rage soaked & shake the crap out of it too. and I have also used the dish washer befor&after to be sure.and also you can get a syphen blow gun and use some laundry detergent,mixed with water, it cleans better than most other methods with about 10 psi.no mater what you use besure to have it clean befor you use it.the syphen blowgun is awassom for cleaning just about everything that gets nasty.kinda like steem cleaning with out all the heat¶faniala.and pressure washers can be hazzardus to the digets&hands |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 8038 Location: OKLAHOMA
Posted: Sun Jul 22, 2012 5:35 pm Post subject: |
When I rebuild any engine I always take the caes and sump to the car wash. Spend a $1.00 and leave the mess there. Don't forget to wear gogles and a rain coat. _________________ 2010 Sportsman ET Champion - Mid-America Dragway - Arkansas City, KS
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 8118 Location: Black Forest, CO
Posted: Sun Jul 22, 2012 5:50 pm Post subject: Re: Deep sump cleaning |
| 1950split wrote: | | I've had a damage on a rod bearing and found small chips on the strainer plate. |
A real oil filter will protect your bearings.
Max _________________ The only thing more expensive than cheap parts is mixing cheap parts with stupidity. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 3693 Location: Madisonville, La
Hotrodvw Samba Member
Posted: Sun Jul 22, 2012 8:28 pm Post subject: |
I used Castrol Super Clean. I sprayed it liberally inside of the sump, rolled it around in my hands to slosh it to all of the corners and let it sit. After about 20 minutes, I rinsed it thoroughly with the garden hose, then dried it with compressed air. Worked pretty well I think. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost lots of money!
Hose & Fittings |
SRP1 Samba Member
Posted: Sun Jul 22, 2012 9:42 pm Post subject: |
| Hotrodvw wrote: | | I used Castrol Super Clean. I sprayed it liberally inside of the sump, rolled it around in my hands to slosh it to all of the corners and let it sit. After about 20 minutes, I rinsed it thoroughly with the garden hose, then dried it with compressed air. Worked pretty well I think. |
Yep that is what I would do, just be careful not to let it sit to long, the superclean will eat the aluminum for lunch.
Once you get it all clean throw it in the dishwasher (laying flat) for a hot wash cycle. _________________ www.srpengines.com
Bugless....... |
Posted: Mon Jul 23, 2012 6:46 am Post subject: |
Dishwasher will clean the outside but it will not clean the inside. _________________ 2010 Sportsman ET Champion - Mid-America Dragway - Arkansas City, KS
Posted: Mon Jul 23, 2012 6:50 am Post subject: |
| vwracerdave wrote: | | Dishwasher will clean the outside but it will not clean the inside. |
And will come with a complimentary divorce as well! _________________ '67 Sunroof
Eric
Hose & Fittings |
Glenn  Mr. 010
Posted: Mon Jul 23, 2012 6:55 am Post subject: |
| Hotrodvw wrote: | | vwracerdave wrote: | | Dishwasher will clean the outside but it will not clean the inside. |
And will come with a complimentary divorce as well! |
Might not matter since you already used the oven to do powder painting at home  _________________ Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club |
Posted: Mon Jul 23, 2012 7:27 am Post subject: |
| my dishwasher has been "updated" for it's new ussage.and does a pretty good job on the inside,but with that said you cant ever be TOO clean so do it a few times, |
Posted: Tue Jul 24, 2012 1:52 am Post subject: |
Murzi, I'll stick to my used sump
I cleaned it yesterday. Used 1L of acetone and let it sit 30min on each side and then used compressed air to dry/blow it.
I just found one little tiny chip. The sump is now bone dry and ready to be fitted. |
