914 Project. Modification and restoration.
Goto page 1, 2  Next
themetalsurgeon
themetalsurgeon is offline
PostPosted: Fri Jul 20, 2012 8:24 pm    Post subject: 914 Project. Modification and restoration. Reply with quote
New project in the shop.The 914 is being converted into a 914-6.Along with the fender flares the first photos show areas of required restoration.The car shows evidence of a light hit on the right hand rear and left side including fender,door and rear quarter.
German car projects
Porsche 356C
Porsche 914-6
Porsche 356A
1958 Volkswagen 15 window
my weekly metal work blog www.themetalsurgeon.com
http://www.themetalsurgeon.com/2012/12/making-a-new-1938-chevrolet-truck-fender-from-scratch/
http://www.thesamba.com/vw/forum/viewtopic.php?t=392073&postdays=0&postorder=asc&start=0
www.themetalsurgeon.com .....know whats under your paint.....
....its not where your from,its where you're at ....
Quote. Ian Brown(Stone Roses)
themetalsurgeon
PostPosted: Sat Jul 21, 2012 7:21 pm    Post subject: Reply with quote
Restoration continued.Tidying up the small areas of repair first.
Bleyseng
Bleyseng is offline
PostPosted: Mon Jul 23, 2012 6:15 am    Post subject: Reply with quote
With adding flares, why not delete the front side marker lites as it looks way better without the hockey pucks sticking out.
Hopefully you have the fiberglass rockers as you fit those first and then align the GT arches to them so everything lines up correctly.
70 Ghia Black convert-stock w/122k 1600 SP-barn find
77 SageGreen Westy Deluxe
Stock w/ 134K 2.0L w/Ljet, Camper Special engine-95hp and with LSD!
76 Porsche 914 2.1L L20c, 120hp Djet
CamperSpecial Club Member
themetalsurgeon
PostPosted: Mon Jul 23, 2012 8:32 pm    Post subject: Reply with quote
why would i use fibre glass rockers?? i dont use fibre anything. ill be converting the original steel ones to the GT arches.
Bleyseng
Bleyseng is offline
PostPosted: Tue Jul 24, 2012 3:12 am    Post subject: Reply with quote
That's great be the original ones were only on GT's and the 916. So a set of molds were made out a OEM steel set. This is the correct way to set up the lines of the flares. Buy a FG set to use as a pattern for making steel ones. Even the 916 bumpers were FG IIRC as they were just prototypes..
If you are making steel parts I would love a front LE spoiler as again those were FG from Porsche and if you hit something explode. Ask me how I know....
monovich
monovich is offline
PostPosted: Tue Jul 24, 2012 10:52 am    Post subject: Reply with quote
Lovely work. Some day it would be great just to see your shop in person. I was pleasantly surprised to see that you are in Denver.
themetalsurgeon
PostPosted: Tue Jul 24, 2012 3:26 pm    Post subject: Reply with quote
Ok relax a little ,everything is in hand ,the side markers will be taken out when the gt arches are grafted in as they 3/4 cover the hole .
The gt arches are just hanging on the car right now to get the look ,nothings grafted in.
The gt arches will be set and grafted into the car after the doors and rockers are hung to ensure car line.
My weekly metalwork blog www.themetalsurgeon.com
themetalsurgeon
PostPosted: Tue Jul 24, 2012 3:29 pm    Post subject: Reply with quote
Colorado is a great place! Your welcome to come by anytime ,thanks for reading the entries .
themetalsurgeon
PostPosted: Tue Jul 24, 2012 5:53 pm    Post subject: Reply with quote
correct way to set the lines???all your showing me is a picture.Isn't that obvious ???
themetalsurgeon
PostPosted: Tue Jul 24, 2012 9:56 pm    Post subject: Reply with quote
The rear show evidence of being lightly hit.Rear inner brackets had to be relieved to gain access to straighten out the drip rail flange.Once straightened the lower section was removed as been previously badly repaired,and upper section pushed up,where rule displays a non straight line.Also this will make ease on replacing rear trunk floor inner right corner panel.
Last photos show the rear panel being filed up and metal finished.
Bleyseng
Bleyseng is offline
PostPosted: Wed Jul 25, 2012 2:46 am    Post subject: Reply with quote
There aren't any measurements available that I know of. Many guys install the flares first then fit the rocker piece and have to modify it to have the correct fitment. Sometimes the flares get attached "off" and it just looks funny.
Setting the flares position using the rocker piece and then cutting the body is easier and the flares look right when you are finished.
The picture is of a 916 with Factory flares and rockers so you can see the placement of em all.
themetalsurgeon
PostPosted: Wed Jul 25, 2012 7:36 pm    Post subject: Reply with quote
Metal finishing right door after removing the bondo.
time taken 3 hours.
themetalsurgeon
PostPosted: Wed Jul 25, 2012 7:44 pm    Post subject: Reply with quote
Metal finishing Left hand door after removing a heavy amount of bondo.This side of the car had definitely been hit at some point in its life.
Using a spoon,various dollies and a file to eliminate highs and lows.
themetalsurgeon
PostPosted: Wed Jul 25, 2012 7:50 pm    Post subject: Reply with quote
LH door restoration continued.
time so far 8hrs
themetalsurgeon
PostPosted: Fri Jul 27, 2012 6:50 pm    Post subject: Reply with quote
This concludes the metal finishing restoration of the LH door.
Total time taken 12 hrs
Slow Steve
Slow Steve is offline
PostPosted: Tue Jul 31, 2012 8:49 pm    Post subject: Reply with quote
Amazing work as usual. My fav is the 15 window conversion so far... Wink
BarryL wrote:
100 years from now when they have reverse atom regeneration attractor technology perfected and in a hand held back yard mechanic's price range, someone will dig up this thread and go, "What were those guys thinking? The whole thing was all there just waiting to be re-atomized. Funny how easily they cut them up back then."
___________________
74 911
72 914
66 Single cab
Sharig1979
Sharig1979 is offline
PostPosted: Sat Sep 01, 2012 6:58 am    Post subject: Reply with quote
Very nice work.
1969 Beetle, turbo 1915
~118 mph on the salt at WoS 2012, 7k in 3rd, can't wait to figure out how to drive that engine on that stuff.
1972 914/4, 1.7
1991 GTI 1.8 8v, 4speed
themetalsurgeon
PostPosted: Wed Sep 05, 2012 10:01 pm    Post subject: Reply with quote
Rear of left hand fender rebuild and 'A' post structure build.
themetalsurgeon
PostPosted: Sat Sep 08, 2012 9:36 am    Post subject: Reply with quote
LH rear quarter rebuild.
themetalsurgeon
PostPosted: Sat Sep 08, 2012 10:18 am    Post subject: Reply with quote
beginning of grafting in the LH rear arch.
Goto page 1, 2  Next
