trooper8 Samba Member
Joined: July 04, 2012 Posts: 19 Location: United States
Posted: Mon Aug 20, 2012 5:17 pm Post subject: Oil drips - strainer bolts |
Last oil change, I installed both new (cardboard looking) gaskets and new copper washers and it still drips from the little bolts. I would think it just had to be so, but at Pomona last week I say a sweet old bus with zero drips!
What's the trick, gasket sealer (permatex 2) on the gaskets? other?
Thanks _________________ After 20 years without a VW there is a 69 Bug survivior in the garage! |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2408 Location: Gladstone, Ore
Posted: Mon Aug 20, 2012 5:23 pm Post subject: |
Maybe start with a new sump plate, they can get dimpled where the 6 nuts go due to years of overtightening.
I never have used gasket sealer, just coat the gaskets with some grease to "glue" them up. _________________ 1972 1302
HPMX 40's & 019 |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Mon Aug 20, 2012 6:41 pm Post subject: |
Use the acorn nuts. They will fill up with oil but it won't reach the ground. Using regular nuts allows oil to pass.
http://images.search.yahoo.com/images/view?back=ht...=yfp-t-701 _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
evilphoton Samba Member
Joined: March 16, 2012 Posts: 394 Location: San Diego, CA
Posted: Tue Aug 21, 2012 10:18 am Post subject: |
maybe more specifically.. use the acorn nuts that come with the oil change/screen kit. they are deeper than "standard" acorn nuts. the seal idea is that the nut bottoms out on the washer rather than on the end of the stud. if they are bottoming on the stud, no seal. I used a caliper to measure the stud length vs. the height of the acorn nuts, make sure the stud is shorter - when fully tightened - than the nut is deep.
however, mine still weep. i use a nut driver to make sure I don't over tighten the nuts. the few times I've checked them, they have been a little on the loose side, so check them every so often - i figure the gaskets squish over time. _________________ '71 SB - 08/1970
[s]34/3 (70/75/75z/135) - 26MPG[/s]
A pair of Kadrons
VW 028 DVDA, stock 1600 DP
'00 VFR
'01 Blazer |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Tue Aug 21, 2012 12:30 pm Post subject: |
As a former VW mechanic and the son of a domestic mechanic learned a old trick back in the late 1930's when observing my dad repair the "dimples" on old 4 bangers and later straight 6 cyl oil pans.
He used then a ball peen hammer to tap down the dimples while I used a sm punch slightly rounded on the VW oil plate.....same results.
Problem many have is not doing that and as a result are over tightening the 6mm nut which ends up stripping out the b lock and now the OIL LEAK..
I learned many tricks from my dad that are a bit different but in the long run are similiar in theory and lasting results. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Tue Aug 21, 2012 12:48 pm Post subject: |
The top surface (facing the engine) must be flat. It's easy to fix on the stamped steel plates, but the aluminum plates are a nice improvement.
Mine are tapped for a 1/2 NPT hex plug.
Part # 93786A125 from McMaster seals much better than the copper washers.
http://www.mcmaster.com/#metric-sealing-washers/=fkx1o7
The FEL-PRO Part # OS21625 oil charge gasket kit is the best I've ever used; 2 bucks at Rock Auto. It includes the copper washers if you insist on using them, but the buna/nitrile sealing washers noted above are much nicer.
http://www.rockauto.com/catalog/moreinfo.php?pk=125859
With this combination of gaskets and washers, there's no reason to even think about over-tightening those delicate M6's. |
jlex Samba Member
Joined: January 23, 2009 Posts: 2902 Location: NW Pennsylvania
Posted: Wed Aug 22, 2012 4:44 am Post subject: |
Mondshine's advice about the Fel Pro kit is right on. When I use any kit other than a Fel Pro, I have some seepage. With the Fel Pro I get no leaks whatsoever.
If you buy at Rock auto, you'll have to figure out how many to buy at one time to obtain the lowest shipping cost per unit. If I remember, getting 3 at a time reduces the cost the most. _________________ jlex.
'70 std. "Elsie"
'88 Carrera |
