Motor mount issue?
Forum Index -> Water-cooled VW Share: Facebook Twitter
sipndiesel
sipndiesel is offline
PostPosted: Sat Aug 25, 2012 9:49 pm    Post subject: Motor mount issue? Reply with quote
81 diesel truck with standard 1.6 l diesel
I notice a considerable amount of vibration at idle but as soon as I increase rpm...it gets very smooth. Is this a motor mount issue or just the nature of the beast? This is my first diesel and I expect some vibration but I am not sure if this is excessive. I did look at the engine mount close to the front and the rubber looks dry rotted but it does appear to be fairly centered in the mount.
Also is it fairly easy to replace this mount?
Any ideas?
gti1977
gti1977 is offline
PostPosted: Sun Aug 26, 2012 2:58 am    Post subject: Reply with quote
changing this rubber is very much work in case that on the same mount plate is injection pump.To much to write it here.About details see manual repair book.This engines vibrations on idle is common thing...is the mount broken or not depends how much it vibrating and how the rubber looks.We cant see or feel it here as you do.
VW Golf mk1 GTI`77,
VW Golf mk1 LD`77,
VW Golf mk1 GX`83,
VW Golf mk2`88 16V G60 project,
Porsche replica.
corrado53
corrado53 is offline
PostPosted: Sun Aug 26, 2012 4:41 pm    Post subject: vibration Reply with quote
Put a small block of wood on a floor jack and place this under motor. jack up the motor a little bit, if the vibration goes away it's a good sign that the mounts are sagging.
Luftgekült
Luftgekült is offline
PostPosted: Mon Aug 27, 2012 6:17 am    Post subject: Reply with quote
I have a similar problem with TD. Not so much at idle, but in gear change. I discovered my front muont not aligned with the recess in the body.
Should I replace the other mounts to get the alignent with the recess or is it adjustable?
'71 VW 1302 1300cc in progress....
'72 VW 1302S 2109cc
'84 Passat Variant GL 1.6TD
corrado53
PostPosted: Mon Aug 27, 2012 9:02 am    Post subject: Mounts Reply with quote
The cup that holds the front mount on the body does have some adjustment.About a half inch up and side play.The front mount failing will cause the other mounts to fail, because it allows too much motor movement and that will stress the mounts.
Luftgekült
PostPosted: Wed Aug 29, 2012 11:53 am    Post subject: Reply with quote
Is the front mount to cup a snug fit?
'72 VW 1302S 2109cc
corrado53
PostPosted: Thu Aug 30, 2012 1:48 pm    Post subject: front mount Reply with quote
Yes a new one will be a snug fit. Check here for some heavy duty options.
http://techtonicstuning.com/main/index.php?main_page=index&cPath=2_11_150
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
