tlcurtis Samba Member
Joined: October 08, 2010 Posts: 19 Location: Kent, Wa
Posted: Wed Sep 19, 2012 11:58 pm Post subject: Extreme Long Build Sears Rascal Manx Clone |
Purchased Sept. 1983 picture when the kids were little. I cleaned the pan and undercoated and I made the mistake of storing outside in the NW winters for several years so starting over.
I have begun recently restarting this project since the kids have moved out were does the time go? I need to Get R Dun will add some new recent pictures. Built a new dolly, removed front and rear end, wire brushing and some light sandblasting.
Check out the rust.
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 2509 Location: Sunset, Louisiana
Bob Elgin Samba Member
pallen Samba Member
Joined: February 15, 2012 Posts: 386 Location: Michigan
Posted: Thu Sep 20, 2012 6:12 am Post subject: |
| Shoot, My PO had angle iron spanning the rusted out spots on the front. I had to cut out my front napolin hat it was so bad! thats just surface rust! |
didget69 Samba Member
Joined: July 22, 2004 Posts: 2805 Location: Capital, North Carolina
Posted: Thu Sep 20, 2012 2:23 pm Post subject: |
Ewwww! Look at the rust in the body lift!  _________________ Internet listed credentials impress no one but Mom... |
Posted: Thu Sep 20, 2012 10:20 pm Post subject: |
A few updated pictures will update as I make more progress
drs1023 Samba Member
Joined: October 20, 2011 Posts: 1098 Location: Georgia, USA
Posted: Fri Sep 21, 2012 1:50 pm Post subject: |
You call that rust?!? I believe most of that would have buffed clean. 25 years at the edge of a northwest Georgia mountain pasture back off in the trees - now THAT'S RUST!
Seriously, you have a lot of good stuff to start with. |
wythac Samba Member
Posted: Tue Oct 09, 2012 8:10 pm Post subject: |
| That is a nice pan, Terry. A good foundation to start with. |
caseydenise Samba Member
Joined: April 25, 2004 Posts: 1307 Location: Essex County, NJ
Posted: Thu Oct 11, 2012 7:49 pm Post subject: |
Keep it up, a dune buggy is like a big kid toy  _________________
| EverettB wrote: | | That is badass |
Posted: Tue Oct 30, 2012 9:08 pm Post subject: Updates: |
A few updated pictures, making some progress.
I am not sure how to seal this gaps on the extension so let me know what your thoughts are on sealing these up. _________________ Check out my build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=528623 |
VolkswagenGerry Samba Member
Joined: February 02, 2010 Posts: 171 Location: San Rafael Ca.
Posted: Tue Oct 30, 2012 10:03 pm Post subject: |
Chewing gum and marshmellows...
Seriously tho if you are not into welding it, You can use aluminum tape (not duct tape) Hvac tape.. molds well around corners.. just run several layers..
I did this to several pin holes on my pan ( after por15 ) then sprayed with self etching primer then rubberized under coat.. worked very well.. cheap and easy..
Or you can use fiberglass cloth and por 15 to saturate cloth.. dries rock hard.
Although metal work is best.. do not use foam filler or good stuff or anything like that..
.IDK just my .02cents |
wythac Samba Member
Posted: Wed Oct 31, 2012 8:17 am Post subject: |
Terry, if you clean the paint off those seams and fab some small wedges from the same square tube, you can bring the pan over to my shop and we can weld it up.
Might be easier on some of those gaps just to take some plate steel carved into the proper shape and weld that in. It wouldn't take more than an hour to weld and clean it up, you'll have more time invested in making the "plugs". |
Posted: Wed Oct 31, 2012 9:37 pm Post subject: Welding Extensions |
Hi Scott, I will work on this and come up with some spacers to weld in and will PM you, thanks for the assistance.
~Terry _________________ Check out my build:
