Pulsating roar from front end
taylorb1
taylorb1 is offline
PostPosted: Fri Sep 21, 2012 5:57 pm    Post subject: Pulsating roar from front end Reply with quote
My front end started making a pulsating roar. Sounds like mud tires (real loud) and i can feel the vibration through the car. Other than that there are no vibration or wobbles that are accruing all the time. Wheel bearings? Brake pedal is solid and no pulsing.
the pulsation goes along with speed
flyboat Premium Member
flyboat is offline
PostPosted: Fri Sep 21, 2012 6:58 pm    Post subject: Reply with quote
Sounds like it could be wheel bearings. Raise teh front and roll the tires by hand. See what it feels like. also check play in the wheel. If it is excessive, you probably need bearings. It's easy to pull the hubs and take a look at them.
79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car
taylorb1
taylorb1 is offline
PostPosted: Sat Sep 22, 2012 7:29 am    Post subject: Reply with quote
Thanks flyboat. do you think re-packing them with grease would help anything?
FergU
FergU is offline
PostPosted: Sat Sep 22, 2012 7:59 am    Post subject: Reply with quote
They are cheap. If you are going to bother taking them out, go ahead and replace them.
1963 Type 14 - Karmann Ghia "Sadie" (Restoration progress - http://vwsexysadie.wordpress.com)
1972 Type 3 - Squareback "Joseph" (Restoration Progress - http://jpdproject.wordpress.com/)
1974 Type 1 - Std Sun Bug "Prudence" (Restoration Progress - http://prudenceproject.wordpress.com/)
2011 Type 7L - Touareg
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Sat Sep 22, 2012 5:31 pm    Post subject: Reply with quote
At $15 each - just replace both (at least) on side where one is bad). Remember to us the new races and replace the rear seal. You'll find rusty grease and bearings that are galled or burnt. Other side needs to be cleaned and repacked too. Probably time to replace both sides rather than a wheel come off at speed or bearing freeze to spindle ruining it.
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW T-Bucket Street Buggy
