jbujtor Samba Member
Joined: April 10, 2009 Posts: 134 Location: Redwood City
Posted: Sun Oct 21, 2012 9:09 am Post subject: Possible bent rear trailing arm - out of spec camber / toein |
1971 superbeetle. left rear camber -3.0, right -.9. Left toein -.65, right .27
left rear camber is way out, even after full adjustment at alignment shop. left rear toe-in also way out. Right rear toe-in slightly out.
They said that either the trailing arms (some call these control arms) are slightly bent after all those years, although not discernable by eye. Bushings all look very good all around from the outside.
The torsion connecting plate bushing is worn a little, causing it to be uncentered a bit, but I'm not sure that would affect the toein. but maybe the camber, but not probably 3 degrees worth!. Spec for camber from Bentley is -1.4 to -.6, so actually only 1.6 degrees out, but can be seen from behind as the top of the left rear tire slants in towards the top of the tranny.
Any ideas? What should I do to fix it? I could ignor it and rotate tires ever couple thousand miles, as the wear doesn't apprear that bad. Does anyone sell trailing arms that have been proven straightened? I can't find any NOS. _________________ 1971 Super Beetle Convertible - Yellow |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun Oct 21, 2012 3:51 pm Post subject: |
Unless the car was racked pretty good, I doubt if the control arms are bent. First thing is what is the ride height - if one side is different, the canber can vary. Not as bad as a swing axle, but it can make a difference.
Toe can be adjusted easily by sliding the wheel forward of back in the trailing arm. That should have been obvious to the aligment shop - but not always. You can also adust the camber a little by forcing the control arm to rotate a little in the trailing arm. The slots can be opened up a little to get even more, but don't over do it.
But before I went through all that, I would replace all the bushings (control arms and trailing arm) if you are sure the bearings are good. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Oct 21, 2012 9:05 pm Post subject: |
The ride height seems to be the same on both sides. The toe-in was adjusted as far as it can be adjusted by sliding the trailing arm where it connects to the spring plate. and still not enough to get it within specs.
The bearings were disassembled and checked 2k miles ago. I completely replaced two of the four joints. The other two showed no visible wear in the races and bearings, so we cleaned them and packed them with the proper grease and put them back together. I'm not sure anymore which side got the new ones and which side the old ones, but I believe they should be good anyhow.
I'm with you on the arms not being bent. But is there a way to check that? If I'm going to replace the bushings, I might as well check the arms if I knew how.
I thought that the piece connecting to the main frame horns with bushings and it connects to the spring plate on the other end is called the trailing arm. Where then is the control arm? _________________ 1971 Super Beetle Convertible - Yellow |
Posted: Mon Oct 22, 2012 4:23 am Post subject: |
Sorry about flip flopping on the terminology - spring plates connect to the torsion springs and trailing arm is trailing arm. Anyway, your CV joints have nothing to do with your issue, so dont be concerned.
Now, why was this taken to the alignment shop to begin with and do they have a clue on how to work on your car? Just for the hell of it, pull your rear tires and look for file marks on the top of the spring plates near the bolts to the trailing arm. Usually when someone does any work, they will file a notch in the top to allow them to put things back where they were.
And for the bushings - I am taking about the ones one your spring plates and trailing arms. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5363 Location: Lefty, CA
Posted: Mon Oct 22, 2012 11:21 am Post subject: |
Rear trailling arms get bent all the time. hell they are 40 years old and metal fatigue is alsways present. I have seen many stock bugs with bent trailing arms. The main reasons are hitting a curb or bottoming real hard in a pot hole. The off road crowd (me being one of them) go to great length to brace up and stiffen the trailing arms.
It is not worth it to try and straigten a trailing arm, it will bend again. Go to a wrecking yard and tray and find a bug that has them still installed. look from the back to make sure that the wheels are straight with know camber and get those. Once they have bent, you can not get the camber and toe right. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Posted: Tue Oct 30, 2012 11:13 am Post subject: |
Yeah, I've been trying to delay going to the wrecking yard as the super beetles are harder and harder to find. I'm not sure what other years/models have the same trailing arms?
It was taking it to the alignment shop because I just wanted to have it checked as it hasn't been properly aligned since I changed all the front end bushings a couple years ago. There wasn't any noticeable 'pull' or anything like that. In fact, I didn't notice the camber problem before, but now when I look from the back, it is very obvious. There are no file notches in the top of the spring plates, so this is probably all original work.
If I'm going to replace the trailing arms or bushings, I might as well replace the other while it's apart....sounds like a winter weekend thing.
So, it sounds like I should change the large bushings where the spring plate meets the torsion springs and also the smaller bushings where the trailing arms meet the frame horns, right?
Lastly, does anyone know if I get get an after market trailing arm that is stiffer and better? Or where how I would stiffen the replacements up if I go through all the work to replace them? thanks again _________________ 1971 Super Beetle Convertible - Yellow |
Posted: Tue Oct 30, 2012 1:09 pm Post subject: |
If you are doing the bushings, bite the bullet and do them all. I am on my second IRS build and I just pull it all apart, clean, paint, rebush and its good for another 40 years.....
As far as beefier (still having probs with them getting bent all the time comments) check the off road vendors. They tend to beef up everything. Here's a couple that I found.
http://www.bugsandbuggies.com/Parts.asp?CN=724&SN=115&GN=8
http://www.chircoestore.com/catalog/product_info.p...l0bpukqdj6 _________________ D-Dubya Manx clone - 63 Short pan,1914.
bent_karma Samba Member
Joined: May 20, 2010 Posts: 291 Location: Modesto, CA.
Posted: Mon Jan 25, 2016 7:07 am Post subject: Re: Possible bent rear trailing arm - out of spec camber / t |
Are super beetles trailing arm the same as a 1971 vw type 3? I lost a wheel while driving and grinder the bottom of trailing arm to the bolt and shock. Thanks in advanced. _________________ '71 VW Bay Window Deluxe Bus [Busness] sold
'73 VW Thing [Agent Orange]
'71 VW Squareback (first air cooled/vw ever) sold
'07 Mazda3 Hatchback GT [the Mazda]
'06 Nissan Sentra 1.8 S (gone at the moment) sold
'18 Subaru Forester 2.5i [Sue Bee]
"Water is for drinking" |
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Mon Jan 25, 2016 8:38 am Post subject: Re: Possible bent rear trailing arm - out of spec camber / t |
An alignment shop that works on medium or heavy duty trucks would/could bend that puppy to spec without a whimper.
Geee that's how they align so many anyway. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Mon Jan 25, 2016 2:58 pm Post subject: Re: Possible bent rear trailing arm - out of spec camber / t |
bent_karma wrote: |
Are super beetles trailing arm the same as a 1971 vw type 3? |
No. If you want to use a Beetle TA, you have to use a 68-70 TA. Those years are the same as your Type 3 TAs. _________________
air-h2o-air Samba Member
Posted: Tue Jan 26, 2016 9:11 pm Post subject: Re: Possible bent rear trailing arm - out of spec camber / t |
be sure you have correct trailing arm to control arm bolts...If they were changed somewhere along the history to a 7/16"(which fits tight)...there we be very little to no adjustment due to no slop in holes |
Bruce Samba Member
Posted: Wed Jan 27, 2016 1:02 am Post subject: Re: Possible bent rear trailing arm - out of spec camber / t |
Multi69s wrote: |
Bruce, what is the difference between Super Beetle and the standard Type 1 trailing arms? I replaced the trailing arms on my Type 3 with type 1s, but they came from a standard Type 1 |
Super vs Standard, there is no difference.
Type 3s with IRS used double spring plates to the end of production in 1973. Beetles used the same double spring plate TAs from 68 to 1970. Then in 71, Beetles and Supers all used single spring plates.
If you think double spring plates are stronger because they were used in a Type 3, you'd be wrong. Porsche 924s and 944s used Beetle TAs with single spring plates, and they are much heavier and have more powerful engines than any Type 3 ever had. _________________
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Wed Jan 27, 2016 7:49 am Post subject: Re: Possible bent rear trailing arm - out of spec camber / t |
Bruce wrote: |
Multi69s wrote: |
If you think double spring plates are stronger because they were used in a Type 3, you'd be wrong. Porsche 924s and 944s used Beetle TAs with single spring plates, and they are much heavier and have more powerful engines than any Type 3 ever had. |
Any idea what the reasoning was at VW as to why they went with either style on the later Beetles? I figure the single was probably cheaper. Why did they make the double spring plates in the first place? Easier to adjust? Stays in alignment with the car better? Overkill? Yeah, I'd maybe go with that last one, but why start with the doubles on the IRS cars when they didn't need them with the swingaxles? Just curious. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
