Installing distributor drive shaft
iamdonquixote
iamdonquixote is offline
PostPosted: Sat Jun 03, 2006 3:10 pm    Post subject: Installing distributor drive shaft Reply with quote
i bought a new mexican longblock and there is no distributor drive gear installed,
why don't they install the drive gear when the build the engine?
can I get one from another engine without the puller?
How does the puller work?
How do I put the drive gear in the case without screwing anything up?
thank you thank you
I thought I was home free with this engine but apparently not.
EZGZ
EZGZ is offline
PostPosted: Sat Jun 03, 2006 3:49 pm    Post subject: Reply with quote
You can use an old distributer drive.
A puller is a good idea.
There is also a small washer (spacer) under the drive gear.
Most books I have seen give detailed distributer install help with pictures. If you don't have a book you can go to a library or take notes at barnes and Noble.
64 custom Ghia, 66 Bug, Sandrail, Barrien tub
iamdonquixote
PostPosted: Sat Jun 03, 2006 4:01 pm    Post subject: Reply with quote
I have how to rebuild your engine but that book tells you to do it with the case halfs apart.
VIN
VIN is offline
PostPosted: Sat Jun 03, 2006 6:36 pm    Post subject: Reply with quote
if your using a stock distributor i believe you have to have the large half toward the cylinders, the slit parallel, with the crack in the crankcase while at TDC. 009 it doesnt really matter. dont forget the shim(s) and carefull of the brass worm gear.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Jun 03, 2006 6:38 pm    Post subject: Reply with quote
Glenn
Member #1009
#BlueSquare
supermanbidder
supermanbidder is offline
PostPosted: Tue Dec 11, 2012 11:42 pm    Post subject: Reply with quote
the above pic I assume that this is at top dead center #1 correct ?
dang chevys were never this much aggravation
supermanbidder
PostPosted: Tue Dec 11, 2012 11:48 pm    Post subject: condensor hits distributor clamp Reply with quote
my condensor (on bosch 019) seems to be hitting my dizzy clamp
Mr. 010
Glenn is offline
PostPosted: Wed Dec 12, 2012 4:47 am    Post subject: Re: condensor hits distributor clamp Reply with quote
Get a early clamp like #2.
Glenn
Member #1009
#BlueSquare
[email protected]
roy@mofoco.com is offline
PostPosted: Wed Dec 12, 2012 8:57 am    Post subject: Re: condensor hits distributor clamp Reply with quote
I install all my dist drive pinions so that the slot is between the dist clamp stud and the fuel pump stud. That will eliminate this problem.
supermanbidder
PostPosted: Wed Dec 12, 2012 9:23 am    Post subject: Reply with quote
is this acceptable placement for it (when on tdc) so my timing will be correct?
supermanbidder
PostPosted: Wed Dec 12, 2012 9:24 am    Post subject: Reply with quote
do you know anyone that might have one ?
