Boost Gauge Pipe Route to Supercharger
boxkiteflyer
boxkiteflyer is offline
PostPosted: Mon Jan 14, 2013 6:50 am    Post subject: Boost Gauge Pipe Route to Supercharger Reply with quote
How do you folks with Judsons et al route your boost gauge pipe? I am going to replace my fuel pipe and thought I might as well route two pipes: one for fuel and other for the SC. Any thoughts or considerations on this? Thanks!
John Moxon Premium Member
John Moxon is offline
PostPosted: Mon Jan 14, 2013 11:45 am    Post subject: Reply with quote
I routed my line through the battery area under the rear seat and then under the mats alongside the tunnel. Up against the front baulkhead to the gauge.
You only need to drill one hole in the pan to gain access to beneath the rear seat.
Make sure the mats don't compress the line although I didn't have any problems with this routing.
John.
boxkiteflyer
PostPosted: Mon Jan 14, 2013 10:05 pm    Post subject: Reply with quote
John- nice pics and thanks! I suppose the pipe comes out of carpet at footwell and runs, exposed, vertically to gauge? My gauge has a flush mount portion so it can be attached to any convenient flat area (like under dash). Your car looks as if it is right hand drive for pipe is on right side of tunnel, correct?
PostPosted: Tue Jan 15, 2013 1:19 am    Post subject: Reply with quote
Yes RHD...I had a nice set of loose fitting coconut mats that covered the lower part of the firewall so the tubing was well concealed and ran to a column Motormeter gauge holder.
John.
D-train
D-train is offline
PostPosted: Wed Jan 16, 2013 1:52 am    Post subject: Reply with quote
i ran my gauge line up the roof line instead of chassis, along side the wiring loom in the oval, no drilling then..
shiny paint doesnt make it worth any more
boxkiteflyer
PostPosted: Wed Jan 16, 2013 1:28 pm    Post subject: Reply with quote
D-train, how did you get the pipe into the passenger compartment?
I'd post a picture of my gauge but, for the life of me, can't figure it out on this site! Mad I've read the instructions but they don't make sense. Other than typing the brackets with 'img' there has got to be an easier way. I post pics all the time on other forums.
D-train
D-train is offline
PostPosted: Wed Jan 16, 2013 3:50 pm    Post subject: Reply with quote
Up through the roof line next to the wiring harness
Out next to the heater demister pipe
Then in through an existing hole
Then to the gauge, sorry about the blurry pic.
Something's there is sound proof stuff in the roofline so might have to run a wire to pull it through.
I use photobucket cause I'm the same an cant figure out the upload pic thing..
I'm a bit special. Haha
boxkiteflyer
PostPosted: Wed Jan 16, 2013 5:12 pm    Post subject: Reply with quote
Even Everett has tried to help me post pics but I'm too stupid or sump'n! D-train and John- do you use steel pipe or rubber hose pipe? I'm currently putting new wiring harness, fuel pipe and everything in my car so I have quite a few options for routing the boost gauge pipe thanks to your input. Thanks for complicating things Laughing Just kidding, dontchaknow!
D-train
D-train is offline
PostPosted: Wed Jan 16, 2013 5:49 pm    Post subject: Reply with quote
Both runnin rubber hose for it, I'd like to swap to steel line, just cause rubber perishes after a while but it works for now so why change it.
While ur doin everything else run it too saves u havin to do it all later when it's more fiddly..
kiwi_obecny
kiwi_obecny is offline
PostPosted: Thu Jan 17, 2013 3:29 am    Post subject: Reply with quote
on our car
http://www.flat4.org/forum/viewtopic.php?f=7&t=12672&start=720
(Sorry only in Czech, but many photos)
My 1964 JavaGreen
http://www.thesamba.com/vw/forum/viewtopic.php?t=486493
Suboval
Suboval is offline
PostPosted: Thu Jan 17, 2013 10:00 am    Post subject: Reply with quote
I agree with D-train - thru the roof (similar to how the wiring is run on the passenger side).
I had an Oval with a Motominder gauge originally installed and the teflon tubing was run the same as D-trains tubing, except on the driver's side.
It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history.
boxkiteflyer
PostPosted: Thu Jan 17, 2013 11:24 am    Post subject: Reply with quote
Thanks for the comments. I'm leaning toward a thru-the-tunnel route whereupon the fuel and boost pipes can be 'married' together but the driver's side roof route is interesting, too!
kiwi obecny- the flat4 forum posts are awesome! The pics were so good I didn't even need to translate! I like the thru-the-bulkhead pipe connectors and how you made those brass ferrules for the ends of your pipes.
