5 Speed Tranny for type 1 engine?
JabaDubRider
JabaDubRider is offline
PostPosted: Sun Jan 20, 2013 3:14 pm    Post subject: 5 Speed Tranny for type 1 engine? Reply with quote
Are there any company's out there that have created a five speed tranny for the bug? I have heard of some puting in gears called a freeway flyer, What advantages are there to this gearing style?
I am unsure as to what kind of transmission combo to build. I drive my rail everywhere, as in to work, the mud, trails, sand, everywhere. The stock tranny has been ok but I want to build a better transmission that will be better. The only complaint that I currently have is the high rpm's at freeway speeds. Missing an overdrive gear is bothering me. Not sure if it's because I have always had one in my other vehicles or not.
So what would be the best transmission combo for my purpose? I just want a good all around tranny that fly's well on the freeway.
America, everybody is in too big a rush. Lay back, take a sip of tea, mow a little grass. Then if you get tired, take a nap.
http://www.thesamba.com/vw/forum/viewtopic.php?t=536093
58Dub
58Dub is offline
PostPosted: Sun Jan 20, 2013 3:24 pm    Post subject: Reply with quote
what is your engine RPM at highway speed? What size tires are on it? Remember, an aircooled engine is cooled with the fan, so you dont want to lower the engine speed too much.
58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project
vwracerdave
vwracerdave is offline
PostPosted: Sun Jan 20, 2013 3:30 pm    Post subject: Reply with quote
The term 'Freeway Flyer' is just a fancy bulshit marketing term used in flashy magazine ads by a company that went bankrupt.
Gene Berg makes a 5 speed conversion kit for a Bug transaxle. Your looking at about $3500 for a built 5 speed.
There are many aftermarket gears available for the Bug. We need to know the vehicle weight, rear tire size, and engine HP to be able to help you choose the correct gearing.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jan 20, 2013 3:41 pm    Post subject: Reply with quote
More than that if you want any heavy duty and performance parts.
Yes they are expensive, but i've had mine for 13 years and never regretted it.
Glenn
Member #1009
#BlueSquare
sobelsaint
sobelsaint is offline
PostPosted: Sun Jan 20, 2013 4:10 pm    Post subject: Reply with quote
Get a Porsche 901 or 902 transmission and pop that in there. Mendeola Suspension has a front mount that makes it easy to install but you will have to make some mods to the frame. You can also get the gears from a 914 and just put those in a 901 case to save some cash.
Talk to Kevin from Mendeola and look at his pics. He does very good work and I have seen his builds as I live close by. http://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=22596
Mr. 010
Glenn is offline
PostPosted: Sun Jan 20, 2013 4:13 pm    Post subject: Reply with quote
More than some mods... don't forget grafting in the Porsche shifter.
And when you're all done, you have a used transmission with gears optimized for a 6 cylinder engine.
Yes, the Berg 5 costs more but you will have a brand new tranny with gears optimized for YOUR specific engine.
Glenn
Member #1009
#BlueSquare
jfats808
jfats808 is offline
PostPosted: Sun Jan 20, 2013 4:50 pm    Post subject: Reply with quote
Berg 5, freeway flyer, superstreet, sodomizer and sodomizer pro. Its still easier to say those terms for the gearboxes than all the specs, because they are understoood. Who cares if they were/are a marketing ploy. Remember (to the op), even with a Berg 5, like any traditional 4 speed u can play with gearing ratios to sut your needs. A Berg 5 in short just moves the modified 4th gear ratio as a 5th gear and slips in a closer ratio between 3rd to 5th as 4th. So you need to really decide if you actually need it. I didnt and bought a freeway flyer ( 3.88- 3.78/2.06/1.26/.82) and saved 2gs plus.
Additionally, theres some mods to make during install i think.
2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
Mr. 010
Glenn is offline
PostPosted: Sun Jan 20, 2013 4:54 pm    Post subject: Reply with quote
Well, a Berg 5 allows you to push you top gear up with a Bus 4th and a 3.875 r/p. Then you fill in the middle gears.
I can cruise all day at 3500rpm doing 80mph.
Are all marketing terms... a Berg 5 is a 5 speed and a different animal.
Glenn
Member #1009
#BlueSquare
modok
modok is offline
PostPosted: Sun Jan 20, 2013 4:55 pm    Post subject: Re: 5 Speed Tranny for type 1 engine? Reply with quote
My mixing and matching the OE ratios, and maybe aftermarket 3rd and 4th, you can usually make a 4 speed to suit your needs without spending over 2000$
You must have small tires on your rail, that or a early bus trans, usually guys run big tires and a bug trans and fourth is TOO TALL
Mr. 010
Glenn is offline
PostPosted: Sun Jan 20, 2013 4:57 pm    Post subject: Reply with quote
You can play with the numbers using my Excel spreadsheet.
http://www.glenn-ring.com/tech/tranny_calc.xls
Glenn
Member #1009
#BlueSquare
jfats808
jfats808 is offline
PostPosted: Sun Jan 20, 2013 5:00 pm    Post subject: Reply with quote
A five speed is still a 5 speed no matter what u call it, is my point. I can cruise all day doing 75 at 2600rpms so frankly i dont see your point. The main point is simply, research and decide whether or not a Berg 5 is something u need or not. I rest my case.
JabaDubRider
PostPosted: Sun Jan 20, 2013 7:25 pm    Post subject: Reply with quote
Wow guys thanks for all the replies in a short amount of time.
I will try to to answer some of the questions.
I am running a 1915 with a 71 bug trans. I have 29" rear tires.
In thinking about what everyone has said I can see why you would not want to have your engine rpm too low at freeway speeds. I guess my only real issue was that I am not used to listening an engine rev at 2700 rpm at 75mph.
Other than that I am quite happy with the stock trans as it has done well for me in every other aspect. I suppose all I need is to beef up a stock trans.
I appreciate all the replies and when Get a chance ( at work right now ) I will go over all the info you guys have put on here and see what would be best for me. Once again I appreciate it!
Teeroy Premium Member
Teeroy is offline
PostPosted: Sun Jan 20, 2013 7:35 pm    Post subject: 5 Speed Tranny for type 1 engine? Reply with quote
If you are only running 2700rpm @ 75mph, you risk cooking your engine. A stock 71 beetle tire is about 25.5" tall, so with a 29" tire and the same gears you are already overdriven.
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Jan 20, 2013 8:12 pm    Post subject: Reply with quote
Confused 40K and the berg 5 needed to be refreshed? i think i'll keep 3k+ in my pocket
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Mr. 010
Glenn is offline
PostPosted: Sun Jan 20, 2013 8:37 pm    Post subject: Reply with quote
I drained the gear lube and found 2 broken spider gear teeth. Also my ZF LSD needed to be rebuilt since it was not done previously. Finally I had some bearing noise and that was due to the bearings not being replaced when the Berg 5 was originally built. I figure they were from the last time my 4 speed (I used it as a core) as rebuilt. That has 130,000 miles for a total of 170,000.
Yes, I cut some corners when I originally had the Berg 5 built.
Here's what I found when I drained the gear lube. 40,000 miles of beating the sh!t out of it.
Glenn
Member #1009
#BlueSquare
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Jan 20, 2013 8:59 pm    Post subject: Reply with quote
^^^^ you cut corners Shocked i didn't think it was in you.
Jake Raby wrote:
Brian wrote:
JabaDubRider
PostPosted: Sun Jan 20, 2013 8:59 pm    Post subject: Re: 5 Speed Tranny for type 1 engine? Reply with quote
My tach has not always worked the greatest. Intermittent at best. so I could be wrong on the Rpm but what I do know is that the engine is reving quite high and its more than im used to, guess I just need to get used to it.
Mr. 010
Glenn is offline
PostPosted: Sun Jan 20, 2013 9:06 pm    Post subject: Reply with quote
My project tarted as a "fix some rust, cheap paint job and stop the engine from leaking". It turned into a complete body tear down, all new paint, new interior, new suspension and engine rebuild. It was September, 2 years later and all I had to do was replace some tranny seals and finish the car. But then i thought... a Berg 5 would sure be nice. So I purchased all the basic parts and had it built locally using my old 4 speed as a core. In hindsight I should of just had it built with all new parts. The money I saved cost me in the end, having to get it rebuild too soon and replace all the parts I cut corners on.
Still glad I did it.
BTW.. Bruce Tweedle rebuilt the ZF.
Glenn
Member #1009
#BlueSquare
modok
modok is offline
PostPosted: Sun Jan 20, 2013 9:08 pm    Post subject: Reply with quote
I don't know how you can even hear the engine over 60 mph, usually the wind is too strong to hear anything Think
Mr. 010
Glenn is offline
PostPosted: Sun Jan 20, 2013 9:09 pm    Post subject: Reply with quote
You can with dual IDAs and minimal sound proofing Wink
Glenn
Member #1009
#BlueSquare
Page 1 of 8
