Go From Dual to Single Carb Setup?
doc hopper
doc hopper is offline
PostPosted: Tue Jan 22, 2013 7:57 am    Post subject: Go From Dual to Single Carb Setup? Reply with quote
I've been driving my 64 Micro for the last 14 years with a dual Solex setup. It's a 1641 engine with high lift rockers. When I got the bus it had a single carb configuration (different engine) and sometimes I just long for the simplicity of a single.
Thoughts on a conversion?
"Honesty hath no fence against superior cunning"
mandraks
mandraks is offline
PostPosted: Tue Jan 22, 2013 8:49 am    Post subject: Re: Go From Dual to Single Carb Setup? Reply with quote
does not sound like it would be a problem? what are your concerns?
regards
Uli
DubStyle
SBS Hit Squad
DubStyle is offline
PostPosted: Tue Jan 22, 2013 9:35 am    Post subject: Reply with quote
I'm running a single carb on my 1835 with a mild stroke and cam. Heck in the past I ran a 1641 with a single carb with zero issues. If you decide to ditch the duals, let me know maybe we can work a trade + cash your way. I'd be running duals if I had the extra cash to spare. Wink
Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club"
Braukuche
Braukuche is offline
PostPosted: Tue Jan 22, 2013 9:44 am    Post subject: Reply with quote
You will notice quite a drop in power, but probably better mileage.
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
jeffreyned
jeffreyned is offline
PostPosted: Tue Jan 22, 2013 10:57 am    Post subject: Reply with quote
I'm currently running a single PICT-2 on a 1641 dual port. It was supposed to be temporary, while I blow a bunch of air through the PICT-3 and try to get it to idle right. But I've loved the simplicity of the carb and don't mind the power loss, so I'm in no big rush to pull it off.
'69 Bay Window Deluxe
'67 Single Cab Dual Chester
doc hopper
PostPosted: Tue Jan 22, 2013 11:39 am    Post subject: Dual Carbs Reply with quote
My bus is primarily an around town kinda rig. Rarely take it on the freeway, not much in the way of hill climbing.
I'm just getting on in years to a point where climbing inside the ass end of the bus to adjust dual carbs and linkage isn't nearly as exciting as it was years ago.
(For that matter, neither is rolling around on the concrete floor doing valve adjustments)
peaceful warrior
peaceful warrior is offline
PostPosted: Tue Jan 22, 2013 12:39 pm    Post subject: Reply with quote
I run a PICT 34 on my 1776, and I agree it is much easier then constantly tuning the duals. Go for it.
The power loss was slight, the gain in mileage was slight, but the joy of not having to adjust the duals for altitude is awesome! Laughing Wink
"Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian
Braukuche
PostPosted: Tue Jan 22, 2013 12:58 pm    Post subject: Reply with quote
Interesting. I also had a PICT 34 on my 1776 and when I went to the dual Kadrons the power difference was huge. And the mileage sacrifice was also noticable. Maybe it has a lot to do with driving style With those Kads I am tempted to do 70mph plus of the freeway whereas with the PICT 34 I was happy to be at 65 and that is in a '65 bug with freeway flyer trans and big nut RGBs.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
zombievws
zombievws is offline
PostPosted: Tue Jan 22, 2013 6:52 pm    Post subject: Reply with quote
oldschool holley bugspray on my 1835. it starts on a dime. idles and is great around town driving. it has decent power on the hwy. fuel mileage is so so. most people scratch there head or ass and ask why are you using that? it works for me thats why.
unique is what we seek, bizarre is what we are.
BarryL Premium Member
BarryL is offline
PostPosted: Tue Jan 22, 2013 7:29 pm    Post subject: Re: Go From Dual to Single Carb Setup? Reply with quote
So they are already single port heads? If not you would have to cut a single manifold and use boots to connect to your dual port heads or else change heads and tins.
peaceful warrior
PostPosted: Tue Jan 22, 2013 7:46 pm    Post subject: Reply with quote
You live at sea level, I live at 7000'! Wink
TOOB Member #15
Brian
