Looking for a cap & rotor
tatersgravy
tatersgravy is offline
PostPosted: Sat Feb 09, 2013 2:12 pm    Post subject: Looking for a cap & rotor Reply with quote
Looking for a cap and rotor for this distributor.
Part #s below ( I think...).
9231081413
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sat Feb 09, 2013 5:47 pm    Post subject: Reply with quote
I don't think those are the right parts for that distributor. Those numbers are for the Bosch 050 - which, while it was made in Brazil like yours was - your distributor doesn't look like an 050. It looks more like an aluminum body clone of an 010 or 019. Maybe Glenn will chime in with advice here...
But, since you asked... you can get those 050 cap/rotor kits here:
http://www.cbperformance.com/ProductDetails.asp?ProductCode=2036
tatersgravy
PostPosted: Sat Feb 09, 2013 6:10 pm    Post subject: Reply with quote
I wasn't real sure about the numbers. I got those from an auto parts store and the fellow wasn't real sure about the numbers. I'll contact the source you offered and see what they have.
Thanks!
The Android
PostPosted: Mon Feb 11, 2013 3:54 pm    Post subject: Reply with quote
I did a little more research on that - found this thread, which says nothing as far as what cap/rotor to use:
http://www.thesamba.com/vw/forum/viewtopic.php?t=235409&start=0
And this ad for what looks like an older version of that same unit, in theSamba Classifieds:
http://www.thesamba.com/vw/classifieds/detail.php?id=1241157
And this listing for a NOS one for sale in Brasil:
http://produto.mercadolivre.com.br/MLB-456573907-d...-farol-_JM
That sort of looks like Bosch 04038 rotor to me.
The cap however, well, that distributor has an alignment lug sticking up, so a Bosch 03010 cap wouldn't work with it, as they are set up for an aligment notch. Maybe one could be modified to work though.
My guess is that you may not be able to find anything that will fit that.
-Andy
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Mon Feb 11, 2013 4:36 pm    Post subject: Reply with quote
bosch 03019 is the black cap pictured above.
88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
tatersgravy
PostPosted: Mon Feb 11, 2013 5:55 pm    Post subject: Reply with quote
-Andy
"Yep" that is the same one as I have!
I also have been talking to some old VW guys here local and was told that the dist. is actually a good piece but, if I can't find a cap / rotor...
Thanks again for your effort!
I'll have to get ahold of "Glenn" in here as he would most definitely know what I need.
tatersgravy
PostPosted: Mon Feb 11, 2013 5:56 pm    Post subject: Reply with quote
Do you know who might carry the parts?
And, thanks for the input!
The Android
PostPosted: Mon Feb 11, 2013 6:09 pm    Post subject: Reply with quote
Glenn will proabably have them. I'm surprised he's not chimed in yet, but I don't know if he looks at the Vintage Speed forum very often. I don't know if that's the best place for this topic actually. Anyway, I'd send him a PM.
That cap also known as the VW part number 111905207B
And just Googling those numbers:
http://www.amazon.com/Bosch-03019-Distributor-Cap/dp/B000GX40N4
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111905207B
http://busdepot2.webappcabaret.net/details.jsp?partnumber=111905207B
http://www.texasaircooled.com/catalog/BOSCH-03019-Dist-Cap-36hp.html
and many others.
tatersgravy
PostPosted: Mon Feb 11, 2013 6:13 pm    Post subject: Reply with quote
I do believe those are the correct caps!
I'll give them a call in the AM and see if they have rotors to match.
Thanks again, you've been very helpful!
Ted
The Android
PostPosted: Mon Feb 11, 2013 7:05 pm    Post subject: Reply with quote
The 36Hp rotor is the 04 008 which replaces the old 111 905 225C. Not sure if that's the one needed here, but if it is, 04008 is the number to use.
Here's some discussion of original vs replacement parts for 36HP distirbutors
http://www.thesamba.com/vw/forum/viewtopic.php?t=251410
tatersgravy
PostPosted: Tue Feb 12, 2013 8:03 am    Post subject: Reply with quote
Very Good!
tatersgravy
PostPosted: Thu Feb 14, 2013 6:36 am    Post subject: Reply with quote
"Texas Aircooled" had the needed parts!
Thanks again for the help and information!
Can always count on good people in here to lend a helping hand!
