tatersgravy Samba Member
Posted: Sat Feb 09, 2013 2:12 pm Post subject: Looking for a cap & rotor |
Looking for a cap and rotor for this distributor.
Part #s below ( I think...).
9231081413
glutamodo The Android
Joined: July 13, 2004 Posts: 26311 Location: Douglas, WY
Posted: Sat Feb 09, 2013 5:47 pm Post subject: |
I don't think those are the right parts for that distributor. Those numbers are for the Bosch 050 - which, while it was made in Brazil like yours was - your distributor doesn't look like an 050. It looks more like an aluminum body clone of an 010 or 019. Maybe Glenn will chime in with advice here...
But, since you asked... you can get those 050 cap/rotor kits here:
http://www.cbperformance.com/ProductDetails.asp?ProductCode=2036 |
Posted: Sat Feb 09, 2013 6:10 pm Post subject: |
I wasn't real sure about the numbers. I got those from an auto parts store and the fellow wasn't real sure about the numbers. I'll contact the source you offered and see what they have.
Thanks! |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4536 Location: Arizona Highways
Posted: Mon Feb 11, 2013 4:36 pm Post subject: |
bosch 03019 is the black cap pictured above. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Mon Feb 11, 2013 5:55 pm Post subject: |
"Yep" that is the same one as I have!
I also have been talking to some old VW guys here local and was told that the dist. is actually a good piece but, if I can't find a cap / rotor...
Thanks again for your effort!
I'll have to get ahold of "Glenn" in here as he would most definitely know what I need. |
Posted: Mon Feb 11, 2013 5:56 pm Post subject: |
borninabus wrote: |
bosch 03019 is the black cap pictured above. |
Do you know who might carry the parts?
And, thanks for the input! |
Posted: Mon Feb 11, 2013 6:13 pm Post subject: |
I do believe those are the correct caps!
I'll give them a call in the AM and see if they have rotors to match.
Thanks again, you've been very helpful!
Ted |
Posted: Mon Feb 11, 2013 7:05 pm Post subject: |
The 36Hp rotor is the 04 008 which replaces the old 111 905 225C. Not sure if that's the one needed here, but if it is, 04008 is the number to use.
Here's some discussion of original vs replacement parts for 36HP distirbutors
http://www.thesamba.com/vw/forum/viewtopic.php?t=251410 |
Posted: Tue Feb 12, 2013 8:03 am Post subject: |
Very Good! |
Posted: Thu Feb 14, 2013 6:36 am Post subject: |
"Texas Aircooled" had the needed parts!
Thanks again for the help and information!
Can always count on good people in here to lend a helping hand! |
