rustydubnz Samba Member
Joined: March 30, 2013 Posts: 5 Location: New Zealand
Posted: Sat Mar 30, 2013 3:32 pm Post subject: end float shims |
hi, i have read and watched a lot about setting the end float so understand that process, however i am a bit confussed about moving the crank in and out.
when i move the fly wheel out it rotates a couple of degrees, i am assuming that it is because of the crank/cam gear meshing and it moves about .035"(2 shims fitted). if i dont let the crank rotate i can get anything less than that.
the crank,flywheel,casings are the same as before the rebuild.
should i be letting the flywheel rotate? |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Mar 30, 2013 4:43 pm Post subject: |
The crank rotation does not mean a lot as long as final end play (float) is .003 to .005 ...
Posted: Sat Mar 30, 2013 5:47 pm Post subject: |
so you mean end float WITH the crank rotation then? |
Posted: Sat Mar 30, 2013 7:32 pm Post subject: |
NO... I mean rotation is non issue.... .003 to .005 total movement.... period.... IF you just do a push-pull on crank/flywheel to set end float there is not going to be enough rotation to make any difference....
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Sat Mar 30, 2013 8:04 pm Post subject: |
Try turning the engine over to where the crank is at top dead center, or bottom dead center, then it usually doesn't rotate when you measure the endplay. |
SRP1 Samba Member
Posted: Sat Mar 30, 2013 11:24 pm Post subject: |
Pull the rockers off. The crank will not rotate now when you move the crank laterally. |
