converting swing axle housing to IRS?????
Todd Miner
Todd Miner is offline
PostPosted: Mon Apr 29, 2013 8:33 am    Post subject: converting swing axle housing to IRS????? Reply with quote
If I weld on IRS pivot perches to my swing axle housing can I use stock IRS spring plates and spring plate rods in this same housing? I want to Make my swing axle into IRS with out cutting the whole unit out. Question
75smith
75smith is offline
PostPosted: Mon Apr 29, 2013 8:48 am    Post subject: Reply with quote
as long as your talking about the torsion tubes and actual suspension then yes, you still need to replace the entire tranny though
My 1975 Beetle Build Updated 8-21-12
My engine build
Todd Miner
PostPosted: Mon Apr 29, 2013 8:54 am    Post subject: converting swing axle housing to IRS????? Reply with quote
Yes using using swing axle torsion housing welded to frame putting 3 rib in , I have the pivot clips , just wanting to know if swing axle torsion housing can be used with IRS spring plates and torsion bars?
slalombuggy
slalombuggy is offline
PostPosted: Mon Apr 29, 2013 9:36 am    Post subject: Reply with quote
Yes
brad
Todd Miner
PostPosted: Mon Apr 29, 2013 10:32 am    Post subject: Reply with quote
Thanks, Samba people , this is the best VW site!!!! On with my build...thanks again. Very Happy
vwracerdave
vwracerdave is offline
PostPosted: Mon Apr 29, 2013 4:31 pm    Post subject: Reply with quote
You need a jig to correctly locate the IRS pivots to weld them on a swingaxle housing.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
Todd Miner
PostPosted: Mon Apr 29, 2013 5:42 pm    Post subject: Reply with quote
were i can get this jig?
Todd Miner
PostPosted: Mon Apr 29, 2013 5:49 pm    Post subject: Reply with quote
Found jigs to get the job done, friend has them, thanks for info.
