Scary noise
Mr.Duncan
Mr.Duncan is offline
PostPosted: Fri May 10, 2013 5:14 pm    Post subject: Scary noise Reply with quote
What does this noise sound like?
Scary :/
Is this "rod nock" Sad
(Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle
FLUX
FLUX is offline
PostPosted: Fri May 10, 2013 7:28 pm    Post subject: Reply with quote
Id try running it very shortly with the fan belt off.. If it still makes the noise it MIGHT be the fly wheel has come loose... But, if it still makes the noise when the fan belt is off Id drain the oil and look for metal shiney bits first.
Mr.Duncan
PostPosted: Fri May 10, 2013 7:59 pm    Post subject: Reply with quote
Fan belt off noise continues.
New Fly wheel was put on by a mechanic 1000miles ago
No metal shavings...
1966 Ghia (sold)
1966 Red Beetle
68IHscout
68IHscout is offline
PostPosted: Fri May 10, 2013 9:12 pm    Post subject: Reply with quote
Take it back to the mechanic
Glenn73
Glenn73 is offline
PostPosted: Fri May 10, 2013 10:32 pm    Post subject: Reply with quote
How is the end play?
Mine sounded like that and I thought the same thing. Tore it down and found out the cam gear was being chewed up, causing the knock.
1973 Super Sat from 93-2008
1986 Vanagon thread Sat from 2005-2017 https://www.thesamba.com/vw/forum/viewtopic.php?t=719692
VW Transporter production film https://www.youtube.com/watch?v=rceTqDtGgz8
Danwvw
Danwvw is offline
PostPosted: Fri May 10, 2013 10:43 pm    Post subject: Reply with quote
That's the engine tin hitting the inside of the crank pulley, Needs a slight tweak with a long flat blade screwdriver. Stop the engine and place the screwdriver on the right side and behind the pulley and shove the tin back a little more. It could make it worse but you will figure out which way to move it through trial and error.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Mr.Duncan
PostPosted: Sat May 11, 2013 3:01 am    Post subject: Reply with quote
This could cause that knocking noise? Or are you talking about the constant rubbing wine?
1966 Ghia (sold)
1966 Red Beetle
Danwvw
Danwvw is offline
PostPosted: Sat May 11, 2013 8:56 am    Post subject: Reply with quote
The whine or screech sound, perhaps that's just the whistle of the exhaust or the whine of the fan belt.
I just listened to mine here: Cold Start, it's a little clunky but I think it's just the fan belt slapping around. Belt sounds will tend to clear up if you squirt water on the belt. Looks like I need to adjust my fan belt. My engine clucks a little bit which I thinks may be due to a small amount of end-play in the crankshaft, I am not worried about it but will rebuild it before another 12000 miles.
johnnypan
johnnypan is offline
PostPosted: Sat May 11, 2013 9:02 am    Post subject: Reply with quote
don't sound like a rod to me...rod knock is distinctive, it sounds like a rhythmic hammer,a sharp knock the gets worse under load.
mukluk
mukluk is offline
PostPosted: Sat May 11, 2013 9:24 am    Post subject: Reply with quote
Agreed, sounds more so valve train related to me. Try using a mechanic's stethoscope or suitable substitute to narrow down where exactly the noise is coming from.
badufay
badufay is offline
PostPosted: Sat May 11, 2013 12:01 pm    Post subject: Reply with quote
My bus once had a similar sound when the rocker arm actually came loose. Pop off the valve cover, check the rocker arms for tightness and since you're there, check the valves real quick too!
Ben
Current: 1976 VW Bus, 3 spd auto 2.0L FI; 2017 GTI S, 6 spd man; 2017 Jetta SE TSI, 5 spd man; 2006 Golf GL 2.0L, auto
Previous: 2015 Golf S TDI, 6 spd man; 2015 Jetta SE TDI, 6 spd man; 12 Jetta 2.5L, 04 Jetta 2.0L, 02 Golf 2.0L, 98 Jetta 2.0L, 98 Golf 2.0L, 98 Cabrio 2.0L, 95 Golf 2.0L, 87 golf GTI 16 valve 1.8L, 86 Cabriolet 1.6L, 80 Audi 4000 1.6L, 76 Audi Fox 1.6L, 76 VW Beetle 1.6L, 74 Audi Fox 1.5L, 69 VW Beetle 1.5L
Danwvw
Danwvw is offline
PostPosted: Sun May 12, 2013 11:18 am    Post subject: Reply with quote
Yeah Mine too. The Rocker would some how shift sideways and come off the valve. Mine kind off sounded like a loud loose valve tappet though on top of the clatter I am hearing on his video. I wonder if it is the flywheel coming loose again. I use Loctite blue on mine. Loctite Blue 242.
truelinebob
truelinebob is offline
PostPosted: Sun May 12, 2013 8:17 pm    Post subject: Reply with quote
loose or busted cam rivets, pull the oil pump and see, just found some on a 1915 a couple weeks ago that had a 3 rivet cam in it.
Mr.Duncan
PostPosted: Mon May 13, 2013 5:05 am    Post subject: Reply with quote
Pulled the engine, the shop put it on an engine stand, they know the noise is internal, but not sure what it is without a tear down....
Flywheel is fine.
Replaced the clutch while it was out.
Later today when its cold, im going to re-torque the rocker arms, and adjust the valves.
Ill update if that fixes it.
1966 Ghia (sold)
1966 Red Beetle
[email protected]
vw@cfrscca.org is offline
PostPosted: Mon May 13, 2013 8:23 am    Post subject: Reply with quote
I had a 1200 that sounded like that. The crank cracked on a stress riser from being drilled for balancing.
It was still held in place by bearings but was in 2 pieces
1974 Standard Beetle to Baja Bug
http://picasaweb.google.com/fvee1234/BajaBug02#
Mr.Duncan
PostPosted: Mon May 13, 2013 8:48 am    Post subject: Reply with quote
Sweet Jesus...
Its been making this noise for 1000 miles...
Hasn't "exploded yet"
1966 Ghia (sold)
1966 Red Beetle
Mr.Duncan
PostPosted: Mon May 13, 2013 3:47 pm    Post subject: Reply with quote
when you say it could be a broken crank, Wouldn't I notice something wrong?
I/E when im driving at 65-70 mph notice some loud issues coming from the engine bay?
Still drives just fine.. its just that noise worries the shit out of me.
Adjusting valves tonight when cold to check.
1966 Ghia (sold)
1966 Red Beetle
Danwvw
Danwvw is offline
PostPosted: Tue May 14, 2013 10:34 am    Post subject: Reply with quote
I just took apart a 74 bug engine that had been run quite a bit with a broken crankshaft. It was spitting case shavings all over behind the flywheel. Needless to say it ruined the case. Photo.
Mr.Duncan
PostPosted: Tue May 14, 2013 1:14 pm    Post subject: Reply with quote
Well, when i removed my engine, i had no metal bits by the flywheel area..
Or inside the oil
1966 Ghia (sold)
1966 Red Beetle
truelinebob
PostPosted: Tue May 21, 2013 7:13 pm    Post subject: Reply with quote
i will bet you it is the cam gear rivets
