VW air-cooled engine flat 8 exist custom or factory...?
Brazimoto
Brazimoto is offline
PostPosted: Sun Jun 02, 2013 8:43 am    Post subject: VW air-cooled engine flat 8 exist custom or factory...? Reply with quote
Hi,
I was wanting to find out, has anyone built an air cooled flat 8 starting with vw style cases..?
Thanks,
Erik
Max Welton
Max Welton is offline
PostPosted: Sun Jun 02, 2013 8:59 am    Post subject: Reply with quote
http://www.shoptalkforums.com/viewtopic.php?f=15&t=141506
Max
1967 Type-3 Fastback
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jun 02, 2013 9:00 am    Post subject: Reply with quote
Porsche did in the 908
Glenn
Member #1009
#BlueSquare
Boolean
Boolean is offline
PostPosted: Sun Jun 02, 2013 10:31 pm    Post subject: Reply with quote
People generally think that the engines must be phased for even firing, but this will make the coupling fail as the two engines try to do different things at the same time. Let both engines fire at the same time and it will work.
It has been done before - I have seen a double VW engine with welded cases and twin cranks, but I suspect that bolting them together is a better solution if the coupling has some degree of freedom.
I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379
Tbirdusa
Tbirdusa is offline
PostPosted: Mon Jun 03, 2013 8:37 am    Post subject: Reply with quote
We boat at Lake of the Ozarks in Missouri and the Baccardi Silver cat had a pair of these bad boys... not VW, but dang, what money can do !!!
Royals 2015 World Champions
Chiefs 2017 Superbowl winner
1986 Falco records Rock Me Amadeus!
Brazimoto
PostPosted: Mon Jun 03, 2013 4:35 pm    Post subject: Reply with quote
Thanks for the responses and input to my question...
O.K. I know about Porsches' 8...
Has anyone made a VW flat 8...?
I did look through the older topic started a few years back, but not any real pics...
I was wondering if anyone's done it recently in 2000's...?
Also, I know a flat 4 can pump out some nice power if built right...
I just was digging around for unique engines for the VW's...
How about a Porsche V10 from the Cayenne in a Bug!!! LOL!
Thanks!
slalombuggy
slalombuggy is offline
PostPosted: Mon Jun 03, 2013 4:53 pm    Post subject: Reply with quote
Here's some prototypes being made in Brail. Not sure how far they got
http://www.thesamba.com/vw/forum/viewtopic.php?t=399470&highlight=fitipaldi
brad
