tig22 Samba Member
Joined: November 14, 2013 Posts: 22 Location: Rocky Hill, NJ
Posted: Sun Nov 24, 2013 4:42 pm Post subject: Where is my wiper motor switch? |
Let me point out the obvious... I'm new.
Where would I find the switch for the wiper motor?
Headlights - Check
Emergency flashers - Check
Turn Signals - Check
Horn - Check
This switch under the dash by the key, that lights up a green light in the cluster - Check
Thanks. |
kjvforme Samba Member
Joined: September 11, 2009 Posts: 222 Location: Oregon
Posted: Sun Nov 24, 2013 4:59 pm Post subject: |
Year, model? |
tig22 Samba Member
Posted: Sun Nov 24, 2013 5:01 pm Post subject: |
1969 beetle 1600cc sp |
gt1953 Samba Member
Well my 68 is on the dash board my 73 is on the right side steering column. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
tig22 Samba Member
Posted: Sun Nov 24, 2013 5:15 pm Post subject: |
awesome thanks.
yeah my wiper logo is missing on the knob... go figure.
THanks for showing me the picture! |
SBD Samba Member
sb001 Samba Member
Posted: Sun Nov 24, 2013 6:41 pm Post subject: |
The switch under the dash by your key is for the rear window defrost
If yours is original and actually works consider it a rarity (the defrost grid that is, not the switch) _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sun Nov 24, 2013 6:43 pm Post subject: |
Take care with that "switch under the dashboard that lights up a green light in the cluster". I believe it's your rear defroster switch. If you leave it on, all the time, you may drain your battery.
Tim |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Sun Nov 24, 2013 7:17 pm Post subject: |
No risk of that, they are only powered when the ignition is on. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76947 Location: Sneaking up behind you
Posted: Sun Nov 24, 2013 7:46 pm Post subject: |
Hm? I've heard that leaving the defroster switch on for long periods (despite the fact that it's only powered while the ignition is on) will drain the battery. Especially if you're also using the wipers, blower fan, headlights--and all that.
Tim |
Brian Samba Moderator
Posted: Sun Nov 24, 2013 9:55 pm Post subject: |
Glenn wrote: |
RTFM
Also the wiper knob insert will only stay in the knob if it has the backing ring. I've never actually seen one before. My 69 came with quarters for insert. PO literally put quarters in the knobs. Who does that? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
don't_bug_me Samba Member
Posted: Mon Nov 25, 2013 5:07 am Post subject: |
lustig69 wrote: |
Glenn wrote: |
RTFM
Also the wiper knob insert will only stay in the knob if it has the backing ring. I've never actually seen one before. My 69 came with quarters for insert. PO literally put quarters in the knobs. Who does that? |
Maybe he traveled a lot of toll roads _________________ 70 Street Baja http://www.thesamba.com/vw/forum/viewtopic.php?t=566113
"Necessity is the mother of invention" |
tig22 Samba Member
Posted: Mon Nov 25, 2013 5:12 am Post subject: |
Do you need the insert to make the knob work? I tried pulling on it like the Headlights and it won't pull out... but it does unscrew.
Thanks for all the responses! |
SBD Samba Member
