beetleseb Samba Member
Joined: November 09, 2006 Posts: 430 Location: Cheltenham UK
Posted: Tue Nov 26, 2013 3:29 am Post subject: Wiring loom details |
Hi Guys,
Firstly, I realise that several people make good wiring looms but I enjoy making them and have found several sources for the components.
The cars a june 1950. Sadly the whole loom was removed before I bought the car.
I have found this link which is a great help for the main loom
http://www.historicvws.abelgratis.com/technical/wiring_looms/split_main_loom.htm
But wondered is anyone had similar details for the front.
Also wondered if anyone knew when they went from cloth outer to PVC outer?? I know the wires should be cloth covered but when did the outer change?
Lastly does anyone know the colour of the thicker dynamo cable (6mm dynamo to battery) and if its orange does anyone have a source for it?? Can only get a few colours that thick unless I order 100m
Seb _________________ Wanted - OG 50 split bug door panels, brown mats and old running boards |
splitjunkie Samba Member
Posted: Tue Nov 26, 2013 5:14 am Post subject: |
The wires changed from Cloth covered to PVC before they switched from the cloth looming. My Oct '51 has PVC wiring with cloth loom except for the harness that goes to the hi beam switch. It is PVC wiring and loom and the loom has Siemens printed on it. _________________ Chris
Posted: Tue Nov 26, 2013 5:40 am Post subject: |
Hi
Cheers dude. Good to know.
I assume my wiring should still be braided. Anyone know for sure? My pod had some remnents of braided cable but who knows for sure if it was OG to the car!
Any more info greatfully received
Posted: Tue Nov 26, 2013 5:54 am Post subject: |
Your car should have the cloth covered wire with the cloth braided loom around the harness. _________________ Chris
Posted: Tue Nov 26, 2013 5:57 am Post subject: |
Cool, thought so
Just need to double check the colour of the 6mm wire that goes from starter to dynamo.
And if anyone has a front loom to measure I would be greatful. Although I can build it in situe and do it that way
Thanks
aa390392 Samba Member
Posted: Tue Nov 26, 2013 10:56 am Post subject: |
I'm not certain whom does cloth wiring for older VW's but this is a great source for those that are interested..... http://www.ynzyesterdaysparts.com/electrical/ _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Tue Nov 26, 2013 4:32 pm Post subject: |
Cheers
Useful company but way too far from me!!
I'm happy with the main loom and the lower front loom for the main lights but would love some info on the upper front loom.
I can chase a few of the wire but without an old loom to copy its a little complex. The closest thing I have to a template is the photo on the zarwerks website
A list of whats in the loom would be great, an idea of dimensions would be amazing! Anyone got an old one to measure
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9359 Location: Northwood, NH USA
Posted: Tue Nov 26, 2013 4:53 pm Post subject: |
I have been making split harnesses for 10+years now. As posted previously, Cloth on cloth would be correct for 1950. As for the battery positive cable, the documentation for 1950 (see the wiring page in the the tech section) calls for black. in '51 it specifies "Black or Red". I sell both, but most people want red.
As for the dimensions of the upper front, below is a partial paste of a spreadsheet that I use to record dimensions. Of course this only gives you wire length, not loom exit location. I have built up a large collection of original harnesses over the years, from '46-'53, as well has Hebs and convertibles, and dimensions I have are very accurate.
I assemble upper fronts on a "nail board" and I do not presently have the harness diagrammed in electronic format that shows wire branch exit locations. I have it "on my list" to do one day, but don't presently have it done. Hopefully the table below is of some use to you.
Also note that 20 gauge wire is not available in cloth from my suppliers and it is the nearest AWG equivalent to 0.50mm^2 wire. For these, I use 19guage. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Tue Nov 26, 2013 5:41 pm Post subject: |
Of Course impeccable work, I misread you were looking for suppliers of cloth wire mybad _________________ .
55 ragtop
56 delux sedan
56 Kabriolet |
Posted: Wed Nov 27, 2013 1:11 am Post subject: |
Hi
Suppliers are always useful. Even if for others and not me.
John. That's amazing and very kind of you to share. I can happily go from there and use the car as the peg board for that upper front.
Thanks again!
Posted: Wed Nov 27, 2013 2:19 am Post subject: |
For any other UK guys I find autosparks.co.uk have most in stock at good prices. They also offer a branding service.
A quick price up reveals you don't save much! Unless like me, you like making looms then buy johns! _________________ Wanted - OG 50 split bug door panels, brown mats and old running boards |
