speedaddicted Samba Member
Joined: October 22, 2011 Posts: 10 Location: Wisconsin,USA
Posted: Tue Oct 29, 2013 5:24 pm Post subject: Volksrod |
Hello Everyone,
I finally got tired of waiting for a volksrod room, and posting my project here.
The Body___________________________________________________
I have alot of the work done, but I swear the last 10% takes 90% of the time, lol. I gave it a 5 inch chop, put in new pans. Welded some louvers into the hood ( I don't recommend anyone do that). Recessed some 51' Oldsmobile tail lamps into the decklid. Painted it with some Rustoleum flat, and Satin. Decided to put some gasser style plexi into it for that vintage feel. Headlights are via a WW2 chevy militray truck. Turn signals I think may be from cab lights from a B model Mack Semi truck. I Filled the radio opening on the dash.
The Suspension______________________________________________
I decided to try just reversing the front suspension instead of making a beam extender. Re-clocked the springs lower on the front beam.I need to install high clearance ball joints yet. Steering is handled by a manual Mustang II rack. I had to re-drill the tapered holes from the other direction, and make them larger to fit the larger Mustang ball joints. I was a bit concerned that the camber was going to get weird, so I made a pie cut in the front horn and welded it shut. This laid the suspension back nicely, and lowered the hood line down where it need to be at the same time.
Transmission________________________________________________
Started with the original swingaxle. I took the trans apart and welded up the cones on 3rd, and 4th syncrows. Installed a superdiff. Put a beefy sideplate on it. Thats it. I think the trans is a bit weak for what im building...time will tell. Please let me know what you all think?
Engine_____________________________________________________
My first performance build on a VW. Building a 2110. Currently in progress. I have two new John Deere generator turbo chargers that I am going to attempt to use in a twin turbo setup. The turbos are designed with only lubrication, no coolant required. Decided to go with the 90.5 cylinders to help with heat, also going to ceramic coat the pistons top and combustion chambers. Using an Engle w110 camshaft. Larger heads with stainless swirl valves, forget right now what ones exactly.GEX something or nother 40x35.5 with dual springs, ported and polished. Chromemoly pushrods. Straight cut timming gear to reduce sideload. Let her make noise! extended sump. large oil pump, remote filter.
I currently have it spaced and shimmed to a static 8:1 with a dynamic 10.1:1 @ 6lbs of boost, Thinking a tune with a 10lb wastegate will put me at 12.75:1 for a strip setup with some race gas. BUT, I currently have a problem.
My Intakes are hitting the pistons with 1:1 ratio rockers. I really want the compression where it is to help the thing out of the hole for street driving. So, I'm going to pocket relieve the pistons around the Intakes for clearance. I'm a bit nervous to remove piston material on a boost car, but it seems from a little digging a bit of clearancing is no prob. Please , any input here would be greatly appreciated. Once thats done. I need to fab some turbo induction tubes to feed a single holley 2 barrel that I still need to pressure port the throttle bushings on.
The PIC_____________________________________________________
Taken at the 2013 MOFOCO Bugfest at the historic Greatlakes Dragaway in Kenosha, WI.
Had the get her out of the garage, even with out the motor done.
[/img] |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Oct 29, 2013 5:54 pm Post subject: |
Looking good...
The current color choices sure look familiar to me ... http://www.thesamba.com/vw/forum/viewtopic.php?t=466290 _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Tue Oct 29, 2013 5:56 pm Post subject: |
Good looking car - LOVE the tire/wheel combo - major old school _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Tue Oct 29, 2013 6:04 pm Post subject: |
Yeah, I recently found youre youtube stuff a couple weeks ago. I Thought, MAN that dudes got great taste......lol, Awesome bug |
1lostVW Samba Member
Joined: September 28, 2011 Posts: 64 Location: Longmont, co
Posted: Tue Nov 19, 2013 9:35 pm Post subject: |
First thing I thought of was your car too. Had to roll back up to see who was posting here. _________________ Melburg LUFT |
crack monkey Samba Member
Posted: Thu Jan 02, 2014 7:34 pm Post subject: |
Looks cool!
Have you posted it on volksrods.com? |
tbucketvw Samba Member
Joined: August 29, 2012 Posts: 9 Location: Morgan Hill, CA
Posted: Tue Jan 07, 2014 1:45 pm Post subject: Very nice I can relate |
Yes the last 10 percent of the build is the hardest. I am working on my second VW rat rod gets harder at the end. |
