twogunpapa Samba Member
Posted: Sun Jan 17, 2010 1:53 pm Post subject: How to remove front seats in 1973 Super beetle |
My husband just bought me a 1973 beetle..she needs a little work but will be so worth it. We need to remove the front seats as the bushings are worn how do we remove them? I saw a post but they didn't say if it was for a 1973 or not.
Thanks for your help..and I've already learned alot by browsing through the forums. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Sun Jan 17, 2010 1:56 pm Post subject: |
There's a safety clip in front of the center slider. Just pull it down and slide them back. They'll come off the tracks and then take them out. _________________ Glenn
Member #1009
#BlueSquare |
ExtraNoise Samba Member
Joined: November 21, 2009 Posts: 38 Location: Olympia
Posted: Sun Jan 17, 2010 5:46 pm Post subject: |
Glenn wrote: |
There's a safety clip in front of the center slider. Just pull it down and slide them back. They'll come off the tracks and then take them out. |
Were the 73s just like the 74 and laters? Our 72 had a little pin on the right-hand rack that needed to be pressed down in order to get the seats to slide off. We couldn't find anything about it in any book or on the internet. _________________ Help me save my VW - check out my Kickstarter project
My VW project blog in case you want to follow along |
kspageddie Samba Member
Joined: July 13, 2008 Posts: 130 Location: Columbus, Ohio
Posted: Mon Jan 18, 2010 8:57 am Post subject: |
U could get hit in the rear of the car and have the force eject the front seat loose...thats what happened to me last summer...lol |
LeviMan2001 Samba Post Whore
Posted: Mon Jan 18, 2010 10:36 am Post subject: |
Look at where the front of the seat attaches. See that little tab? push that down then pull the seat straight back untill it comes off the tracks _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=366056 - My '73 Super Build. 2332cc, 16" Fuchs |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Mon Jan 20, 2014 4:54 pm Post subject: |
does this apply to a 71 super beatle. ? i pull on the lever the seat slides but doesnt come off the rail . im pushing towards the steering to remove the seat. i dont see a pin? i have the lever turned so it doesnt engage the teeth but doesnt slide out. _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
binky13 Samba Member
Joined: October 16, 2013 Posts: 72 Location: PHILADELPHIA
Posted: Tue Jan 21, 2014 4:18 am Post subject: |
my release pin loves to slide out at inoppurtune times and dump me on the floor. I always have to laugh _________________ 59 Semaphore |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Tue Jan 21, 2014 4:48 am Post subject: |
hsosa1 wrote: |
does this apply to a 71 super beatle. ? i pull on the lever the seat slides but doesnt come off the rail . im pushing towards the steering to remove the seat. i dont see a pin? i have the lever turned so it doesnt engage the teeth but doesnt slide out. |
No,that is only 73 and later with the 3 point runners.
the twin rail you've got have a release tab on the right runner at the front that needs pushing down. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32598 Location: Reading Pennsylvania
hsosa1 Samba Member
Posted: Tue Jan 21, 2014 5:18 pm Post subject: |
Ok yeah its not a 74 . just a 71 which has the the lever. it looks like the rail end which kinda looks like an arrow head is getting stuck on the rail. looks like i will need to grind dow that metal end. to get the seat off only thing i can think of. it looks lit the end doesnt pass through the guide and just hits near the spring on the right passender rail. i tried to straigten the end but now im going to just grind it down or maybe use a file so it can pass through the rail . _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
GARYVONT Samba Member
Joined: May 05, 2013 Posts: 59 Location: ESCONDIDO, CALIF.
Posted: Wed Jan 22, 2014 3:20 pm Post subject: |
I had this identical problem on my '71 Super. Mine has small metal tabs located at the front, right, side, just outside of the tracks. FIRST, remove the coil springs that pull the seat forward. Push the tab down and push the seat forward (both actions at the same time) and off the track. You may need some help pushing it forward. If there is a "sticky" on this, some kind soul sent me some excellent photos when I was inquiring. Good luck! |
Posted: Wed Jan 22, 2014 3:21 pm Post subject: |
hsosa1 Samba Member
Posted: Wed Jan 22, 2014 4:25 pm Post subject: |
do u have any pics of the that tab? its not the actual lever that turns the metal piece to lock into the teeth correct? ill look for the tab. i didnt see the return spring underneath im suspecting it was pulled out. is the tab on the actual seat rail of the seat or is it part of the rail welded to the pan? _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
Posted: Thu Jan 23, 2014 9:59 pm Post subject: |
I found the tab difficult to find, but once you do find it, you'll wonder why it was sooo hard. It is NOT the lever that disengages the seat so it will slide. Look at the right front corner of the right hand track, just to it's right corner area. You may have to dig through some carpet to find it. |
Posted: Thu Jan 23, 2014 10:00 pm Post subject: |
hsosa1 Samba Member
Posted: Thu Jan 23, 2014 10:42 pm Post subject: |
Ok ill look tommorrow. i remember on my 1st 71 that i had . i had no problem removing the drivers seat. over 20yrs ago i remember wanting to have lowbacks . also remember swearing i would never buy a fatchick. again lol _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
hsosa1 Samba Member
Posted: Fri Jan 24, 2014 8:44 pm Post subject: |
ok today i found the tab. i took a picture placed a nickel on the tab that you push down on. for future reference. this is for a 71 superbeetle front seat removal. spray wd40 etc. clean around tracks. i used a tall flat file to push down on the tab while i pushed the seat off the track. _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
Posted: Sat Jan 25, 2014 11:07 pm Post subject: |
While you have it out, you may want to find out if the '71 Super used plastic/nylon (?) skids on the rails. My seats were real sloppy, and there were no skids on them. If so, I will definitely add some if I end up using the stock seats. |
Joe1stBeetle Samba Member
Joined: April 02, 2012 Posts: 65 Location: Northwest Indiana
Posted: Sat Jan 25, 2014 11:22 pm Post subject: |
I have a 73 standard beetle. You remove one little Philips head screw then pop the little clip back and that part is free. You have to pull your forward adjustment lever so the big pin clears the hole and the seat will slide right out the back. Very simple. About 1 minute and you are holding your seat outside the car. Not sure if the super is any different. I wouldn't think so on a 73 |
