hiperman70 Samba Member
Posted: Sun Mar 06, 2005 9:37 pm Post subject: windows removal |
hi,need help on how to remove the 2 side windows they are stationary and the rear window with out destoring the rubber seals?
thanks |
howiesfamily Samba Member
Joined: March 31, 2004 Posts: 858 Location: Panther City, Texas
Posted: Sun Mar 06, 2005 9:40 pm Post subject: |
A hammer would do the trick. It wouldn't mess up the rubber. The windows on the other hand.... _________________ member of: Fort Worth Aircoolers Gang |
Barter_Builder 69 FI/AC
Posted: Sun Mar 06, 2005 9:46 pm Post subject: Re: windows removal |
hiperman70 wrote: |
thanks |
I would think to lube the inside of the window seal with wd40 or something and just kick it out. Make sure someone's on the other side catching it. I don't know where your located but doing it on a really hot day would prabably be best. |
Posted: Sun Mar 06, 2005 9:56 pm Post subject: Re: windows removal |
so,what you saying is save the window or the rubber?cant save both?
thanks i guess i will save the windows |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Mar 06, 2005 10:12 pm Post subject: Re: windows removal |
hiperman70 wrote: |
If the rubbers are old and hard, that is about it.
The rubbers can be purchased cheaper than the glass. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sun Mar 06, 2005 10:25 pm Post subject: Re: windows removal |
ok thanks,one more question ,to install the headliner all the windows need to be out right? |
Posted: Sun Mar 06, 2005 10:40 pm Post subject: Re: windows removal |
hiperman70 wrote: |
Yes, if you want the headliner to be right.
It is installed from the factory before the glass is installed. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
60DoubleTurd Type 3 Contributor
Posted: Mon Mar 07, 2005 12:20 am Post subject: |
I always have a buddy staning on the outside of the car waiting to catch it as you are inside with both feet and even pressure on the window. I havent broken one yet and I've done lots!!! _________________ Frank
66 L87 Variant Pigalle
SBS #17 |
