VEEDUBACE Samba Member
Joined: July 01, 2004 Posts: 29 Location: daly city, CA
Posted: Sun Mar 06, 2005 11:37 pm Post subject: dropping a 65 notch. |
ok, so i just got done lowering my notch. i went 2 clicks up front and 2 outter and one inner on the rear. i'm running 165/15s all around on 5.5x15 8spokes. i have major rubbing issues up front, and the rear still sits a good deal lower. does anyone have any info for me?? i'm trying to achieve a good low stance. i know i need different tires up front, but i'm wondering do i just order a standard 135, or should i try to find like a 145/50 or something like that? _________________ 66 notchback-hoodride
2002 S-10 Xtreme fully custom daily driver |
speed holes Samba Member
Joined: March 04, 2004 Posts: 403 Location: Fat City, USA
Posted: Sun Mar 06, 2005 11:49 pm Post subject: |
First off, 8 spokes are wider than stock, and the offset is lower, meaning the tire is pushed out further towards the fender. You'll definitely need some 135's or 145's up front to help with the rubbing issues. 135's are also a lot shorter than 165's, which may bring the front down level with the rear. your speedo will be off, but you'll get used to it.
2 outer clicks and one inner is quite a bit for the rear, you might want to go back up one outer, or just go 3 outers and no inners. It takes a bit of trial and error sometimes to get the stance just right.
Have fun! |
Posted: Mon Mar 07, 2005 12:37 am Post subject: |
sweet, maybe i'll try that for the rear. it tucks hard, and looks awesome, well, to me at least. _________________ 66 notchback-hoodride
