1975 Kombi Samba Member
Joined: August 12, 2007 Posts: 2452 Location: Acton, Ontario, Canada
Posted: Fri Mar 14, 2014 6:46 pm Post subject: 2003 TDI passenger side motor mount sheered bolts off. |
This is odd but the passenger side engine mount that sits inside the timing belt area has sheered the 2 bottom bolts clean off that secured the mount to the engine and left part of the bolts in the engine block and left 1 remaining bolt that slightly bent but held the mount and the engine 3" lower then normal. I have removed the sheered bolts from the block and replaced the everything back to normal but now the CV or wheel bearing is making a rotational noise that worsens with speed.
So the question is could the 5 miles that I drove the car after the bolts were sheered off due to hitting a pot hole have bent the CV enough to destroy the ball bearing inside the cv joint or messed with the wheel bearing on the driver's side? _________________ Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v |
jakehenes Samba Member
Joined: March 18, 2007 Posts: 96 Location: milwaukee wisconsin
Posted: Mon Mar 17, 2014 7:24 pm Post subject: |
It was probably damaged in the first 5 seconds after motor dropped. By the way the bolts breaking are usually cuz they are to torqued correctly after a timing belt replacemt _________________ Owner and mechanic - riverwest auto. |
73sports Samba Member
Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
Posted: Tue Mar 18, 2014 6:17 am Post subject: |
Make sure the axle is not bent. _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
mintonman Samba Member
Joined: October 20, 2003 Posts: 4245 Location: between Trenton NJ. & Philly Pa.
Posted: Thu Mar 27, 2014 7:52 pm Post subject: |
Might want to check the dog bone as well, might be beat and allowed the motor to move enough to shear the bolts off when you hit the pot hole. _________________ Hoockd on fonicks werkt for mee?
under the influance "DUH" |
