GüteAndTite Early Convertible Güru
Joined: June 16, 2005 Posts: 2144 Location: Low So Cal
Posted: Wed Apr 16, 2014 5:36 am Post subject: Virgin 1958 dash- where to mount cigarette lighter? |
SO, I have one of these paluxette 6v coffee makers for my car and i need to install the 6v original dealer accessory cigarette lighter in my car so i can use the lighter and also have a cigarette lighter.
So heres the kurfuffle: I have mounted a clock, sapphire II radio, record player, air conditioner, gas heater and dehne gas gauge (not pictured) all without cutting any holes in the face of the dash. I have only cut holes where the speaker grill is for the dehne gauge, but put away original grill, and used another that I painted to match. So its reversible.
SO, im trying to figure out where I should mount the cigarette lighter. keep it mind that the coffee maker sticks out from the dash about 6-7 inches, and probably should be away from spilling on record player, or in the way of ashtray, shifter , and radio knobs. I really dont want to cut holes in this virgin dash, but if I do since its an original accessory, it should be in a proper OG spot, or at least look like it would be OG. It also needs to be functional and not awkward. what do you guys think based on this picture?
_________________ Official 58-60 "Early Big Window" Convertible Thread & Registry
http://www.thesamba.com/vw/forum/viewtopic.php?t=426481
F&S Saxomat Automatic Clutch System Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=462533
61-67 Delanair Air conditioning Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=457944&highlight=air+conditioning
PUNCTUATION CHANGES THE WORLD: "I need to help my uncle, Jack, off a horse" is way better than, "I need to help my uncle jack off a horse" |
mrmdls Samba Member
Joined: April 27, 2013 Posts: 410 Location: New Brunswick, Canada
Posted: Wed Apr 16, 2014 6:07 am Post subject: |
I am not at all envious of you having to even think of cutting your beautiful dash. I have a 59 ragtop, that I'm going thru that sat for an extremely long time (it still has a 62 license plate on it). It had a cigarette lighter installed where your vase is located (it also has a huge tube am radio that was installed under the dash). Personally, where you have such a beautiful dash, I'd hid it in the glovebox. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Wed Apr 16, 2014 7:16 am Post subject: |
I'd make a metal bracket and use existing bolt(s) like the steering column mount bolt near "A", so I wouldn't need to drill or cut.
I did something similar under the steering column on my truck a few years back so I wouldn't have to drill or cut anything there (I added a toggle switch there). _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1774 Location: Winnipeg
KTPhil Samba Member
Posted: Wed Apr 16, 2014 9:02 am Post subject: |
I'd go for the modified spare ashtray solution. Totally reversible, convenient. |
mrmdls Samba Member
Posted: Wed Apr 16, 2014 9:06 am Post subject: |
After seeing the modified spare ashtray. I would go with that! It's absolutely brillant! |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Wed Apr 16, 2014 11:04 am Post subject: |
Why not make a bracket that that mounts to one or both of your shifter mount bolts? Then you can run the wires under the mat and directly to the battery. _________________ Mother Nature is a Mean Evil Bitch! |
KTPhil Samba Member
Posted: Wed Apr 16, 2014 11:55 am Post subject: |
Expect a vehicle and body search should you be pulled over, since that thing will look like a bong to a cop! |
drs1023 Samba Member
Joined: October 20, 2011 Posts: 1682 Location: Georgia, USA
Posted: Thu Apr 17, 2014 5:33 am Post subject: |
Maybe you should mount it in your other car. The '59 is pretty full of distractions already.
I'm not judging, but if you drive your car long enough distances that you need to refill l your coffee cup, perhaps you should consider just stopping at the nearest QT and getting another cup. On the other hand, if you need coffee at a car show, I'd just put the outlet in the trunk. |
KTPhil Samba Member
Posted: Thu Apr 17, 2014 8:16 am Post subject: |
It comes with a funnel and hose, so he's covered for those long drives.
bluebus86 Banned
Posted: Thu Apr 17, 2014 11:11 am Post subject: |
for me, don't cut the dash, instead mount the lighter on a right angle bent piece of metal hung under the dash with a small screw(s) I did that in my 61 bug. I did not want to hole up the dash face.
PS do you have some photos to share of your AC install, photos of engine bay and underside heat exchangers and such. that is an interesting ac unit. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Thu Apr 17, 2014 7:32 pm Post subject: |
drs1023 wrote: |
I don't own a 59- this car in question is a 58, coffee maker and cigarette lighter are going in this car. It's not full of distractions- they are all functional , rare and period correct original parts that make driving the car very enjoyable. I do not have brand new aftermarket ridiculousness.
I don't know what a qt is- we don't have those stores in California. Maybe an am/pm or 711. I think ill drink my espresso in my car instead of their Mississippi mud coffee _________________ Official 58-60 "Early Big Window" Convertible Thread & Registry
Posted: Thu Apr 17, 2014 7:35 pm Post subject: |
bluebus86 wrote: |
PS do you have some photos to share of your AC install, photos of engine bay and underside heat exchangers and such. that is an interesting ac unit. |
I'm highly leaning for this option.
The a/c is from a 1960 and is a dealer installed a/c made by Delanair exclusively for volkswagen. I have the complete original system and it's mounted to a 36hp motor. _________________ Official 58-60 "Early Big Window" Convertible Thread & Registry
