Maxoceanblue Samba Member
Joined: June 27, 2013 Posts: 429 Location: Pensacola, FL
Posted: Wed Apr 16, 2014 12:10 pm Post subject: Which is power, which is ground |
Got these fog lights, they came with two wires attached, a white and a red one. I assumed the white was the ground and the red was the power.
When I opened the lamp to find out the wattage of the bulb I found this:
To me it looks like the red is the ground and the white is the power. Am I correct or wrong? Does it matter if I get them switched? _________________ 1964 Beetle Sedan/1600cc DP 12v converted |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Apr 16, 2014 12:20 pm Post subject: |
yes it looks like red is ground and no you don't want to mix them up unless you want to fail the smoke test _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Wed Apr 16, 2014 12:41 pm Post subject: |
Ok thanks. I guess I should open up the other one just to make sure one is different than the other. _________________ 1964 Beetle Sedan/1600cc DP 12v converted |
Posted: Wed Apr 16, 2014 1:34 pm Post subject: |
yes that would be a good idea to check the other one. I've seen the same parts wired different _________________ Rick
tasb wrote: |
sb001 wrote: |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Wed Apr 16, 2014 1:53 pm Post subject: |
The white lead looks like just the extension of the bulb's wire, which is typically white from the woven insulation they usually have for better heat resistance. The mistake is the red ground wire, which should be brown (preferably, or black) to signify ground. |
Jon Schmid Samba Member
Joined: May 29, 2012 Posts: 2038 Location: Southern California
Posted: Wed Apr 16, 2014 2:06 pm Post subject: Which is power, which is ground |
That crimp job on the red wire is interesting. I would prefer to have the lower part of the lug crimped directly onto the copper conductor. The upper crimp on the insulation is fine as it is for strain relief. Just my opinion. |
KTPhil Samba Member
Posted: Wed Apr 16, 2014 3:13 pm Post subject: Re: Which is power, which is ground |
Jon Schmid wrote: |
Correct and another reason to replace that wire. Sloppy. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31373 Location: Hot Arizona
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Wed Apr 16, 2014 4:21 pm Post subject: |
That is beyond sloppy, it is a defect for class 1, 2, or 3 IPC standards. The insulation must end in the window between the insulation fingers and the contact wings of the connector. To have insulation crimped into the contact wings is a clear defect... at the least, solder it up; at best, replace the connector.
Might it be English, wired for positive earth systems like Lucas loved to use? |
KTPhil Samba Member
Posted: Wed Apr 16, 2014 4:32 pm Post subject: |
Harleyelf wrote: |
Lucas? Explains a lot...
gt1953 Samba Member
Posted: Wed Apr 16, 2014 4:44 pm Post subject: |
I would use a VOM (volt ohm meter) and check continuity between lamp case and one of the leads. It appears to be a sealed beam lamps. Not sure could not get past the crimp job. Oh Lucas hmmm. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Wed Apr 16, 2014 4:52 pm Post subject: Which is power, which is ground |
Harleyelf wrote: |
Guys, I didn't mean to unleash an IPC based anal attack on the crimp joint, just a simple observation that it could be done better, that's all. The light isn't going into a freaking satellite, now, is it? |
Posted: Wed Apr 16, 2014 5:27 pm Post subject: |
Well I've already hooked them up without reading about all the crimping discussion. Works fine so far. If they should fail I'll be sure to check "the crimp"
Thanks all. _________________ 1964 Beetle Sedan/1600cc DP 12v converted |
KTPhil Samba Member
Posted: Wed Apr 16, 2014 9:14 pm Post subject: |
A high resistance connection will get hot. Maybe hot enough to ruin your light. Have you installed a fuse and relay? If not you can toast your switch and maybe do more serious damage. |
old_n_slo Samba Member
Joined: August 08, 2009 Posts: 269 Location: Air-id-zona
Posted: Wed Apr 16, 2014 9:36 pm Post subject: |
gt1953 wrote: |
It appears to be a sealed beam lamps. |
Its not a sealed beam. |
vwpackrat Samba Member
Posted: Thu Apr 17, 2014 6:29 am Post subject: |
id replace the ground with a black wire just for the fact the red is so bright and ugly and also so you dont have a splice connection outside the car. Run full lenghth wires all the way to fuse panel. _________________ 62 Convertible Bug
67 Westfalia |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Apr 17, 2014 8:23 am Post subject: |
I agree- establish some sense right now (or slip on some cheap black shrink tube)- so a roadside repair in the dark makes more sense later. The spade on the bulb's plus wire is easy- it's so whatever hot lead is running to it- it has a shielded female spade- so no accidental shorting (cause you know how people are so good about working with electrical while the battery and accessories are hot).
I can't believe nobody has addressed that ridiculous crimp job! _________________
EverettB wrote: |
FU#5 |
drs1023 Samba Member
Joined: October 20, 2011 Posts: 1682 Location: Georgia, USA
Posted: Thu Apr 17, 2014 1:33 pm Post subject: |
Lucas - Prince of Darkness - ha, ha, ha!!! Haven't heard that since I weaned myself from my brief (yet unproductive) daliance with British Leyland cars. I tried once to trace down a wiring fault in a 70's Jag XJ 12. When I removed the console, it seemed like EVERY single connection had a label with someone's name on it. When I found the issue, it seems that a bloke named Robert didn't know jack sh*t from peanut butter about connecting dual fuel tanks selector switches. |
Posted: Thu Apr 17, 2014 3:47 pm Post subject: |
Yea I used a fuse and relay and shrink wrapped the connections. _________________ 1964 Beetle Sedan/1600cc DP 12v converted |
