Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sat Dec 28, 2013 8:57 pm Post subject: |
Probably. Look up into the engine air scoops on the upper rear corners outside. If you see a metal tube on the inside, near the top, about an inch or two in length, then that's it. One per side. The rear tubes do not extend to the bottom of the bus like the forward tubes do. My 1977 bus has four drain tubes, so yours should too. |
makin' boost Samba Member
Joined: July 15, 2013 Posts: 17 Location: Pac Northwest
Posted: Sun Dec 29, 2013 11:32 am Post subject: |
I'll have a look today. Thanks for the info ................... |
Posted: Mon Dec 30, 2013 8:40 pm Post subject: |
It appears my '79 sunroof bay has drain tubes between the slider and passenger door and drivers door and the panel, at the front jack location, with another pair at the extreme rear, left and right
I looked at a '71 sunroof bay today and it has 3 drain locations. similar to the '79 with another, left and right at the rear jack locations. |
Posted: Mon Dec 30, 2013 9:02 pm Post subject: |
By your description, am I correct in thinking the rear drains on your bus extend down to the rocker panel level? My rear drain tubes end just inside the air scoops, about 5 1/2 - 6 feet off the ground. |
Posted: Tue Dec 31, 2013 6:46 pm Post subject: |
Wasted youth/adulthood wrote: |
The rear drain tubes on my '79 extend about 3" - 4" below the "gutter" rail ?, inside the air scoop area. I'm not sure yet where the water exits from the air scoop area.
There is no plastic/metal tube extending down through the engine compartment on either side as on the '71 is viewed yesterday. I have not gotten back there yet to check if they are clear of debris.
My headliner is reasonably trashed, needing replacement, so I cut it to expose the inside of the rood area at the door jamb area on both sides.
I took some 12 gauge wire and pushed it up the drain tube after cleaning out the road debris by the jack point on both sides.
The wire went up to the roof area, I then went from the top down on the passenger side. The wire traveled 6"-8". So there must be an angle transition from the roof area to the vertical drain down to the jack point.
I poured some water down the passenger side drain inside the sunroof and holy s**t water was on the floor of the garage.
The driver side was clogged at the so I cut a section out of the plastic tube, went to the local hardware store and bought some new plastic tubing in various sizes. The smallest diameter tube fits through the existing tube of the sunroof to the drain in the door jamb. More water down the tube and the same result, water on the garage floor. A little bit of effort but I think both sides are now clear of debris.
My next move is to get the metal sunroof panel out. The cables are broken but it slides back and forth with ease.
I think the long term preservation solution for the front drain tubes is to plug the tubes at the jack point,pour some Por-15 or similar material down the tubes, let it soak in, remove the plug and drain it. |
SGKent Samba Member
Posted: Tue Dec 31, 2013 10:15 pm Post subject: |
I had to replace one panel on my bus during resto and the replacement came off a donor that they cut right down the middle of the B pillar. The tube is steel, like electrical conduit, comes down and makes a bend inside the pillar then exits at the bottom where there is a black plastic piece called a valve in the parts book.
The tubes rust and get thin. POR15 should work, The only other solution I can think of unless you cut the B pillar open (what a mess that would be) would be to run thin wall plastic tube inside it or POR15 it before it rusts thru.
Once it is open you could float a piece of nylon string thru it with LIGHT compressed air and use that to pull on the thin wall plastic tube while someone fed it in at the top maybe with some grease on it. |
Posted: Wed Jan 01, 2014 6:24 pm Post subject: |
Doing the surgery on one of the drain tubes would be ugly, way beyond skill level and pay grade.
Today I took some tubing and a funnel creating a "beer bong" type device and poured 1 gallon of water down each side. The drives side has some debris in the pan, the passenger side was pretty clean. I concluded two things;
#1 The drain tubes are solid and don't leak.
#2 The application/theory of a material such as Por-15 should work to seal and preserve the drain tubes. Even though this bus spent most of its life in the Pacific Northwest, probably outside, its pretty clean with only minor surface rust. It has lived inside since I have owned it and will continue to do so.
The short rear drain tubes on the passenger side just flow down into the area where the battery is located. I think the simple solution going forward will be to feed some plastic tubing up from the battery area and slip it over the drain tube. I cannot see up the drives side due to the gas heater. I assume the same procedure will work once I remove the gas heater.
What were they thinking at the factory with external water draining down into the location where the battery was located. No wonder so many of those corners are rotted out.
So going forward I have a couple of questions;
How do I get the sunroof panel out ?
How do I get the aluminum track out, that is covered by the rear "tray or shelf" that the sunroof slides into ?
The end goal is a 911 powered bus with Porsche hubs and brakes. |
Posted: Wed Jan 01, 2014 7:18 pm Post subject: |
Yes, draining the sunroof onto the battery tray...or anywhere into the engine compartment... is unwise, in my opinion. That does seem to be where it goes, but there is also a drain for the battery tray, so maybe VW figured it would be OK to do that? I don't know, maybe there is more to this than meets the eye?
As far as getting the roof components out, the subject is covered in the Bentley, Sect. 1 Body and Frame, Item 8 -Sliding Roof, pages 41 through 45, and also see SGKent's thread on this subject.
I just did all of that about a week ago. Just be patient, and get a helper to lift off the roof panel when that time comes. You can PM me if you like, while this is fresh in my mind. |
jakokombi Samba Member
Joined: August 15, 2010 Posts: 779 Location: Milwaukee
Posted: Wed Jan 01, 2014 7:30 pm Post subject: |
The rear drain tubes on my '79 extend about 3" - 4" below the "gutter" rail ?, inside the air scoop area. I'm not sure yet where the water exits from the air scoop area.[/quote]
Really?? On my 70' they run all the way down to, and through the engine room floor.
Was this a late bay change?... _________________ 70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja |
Posted: Wed Jan 01, 2014 8:14 pm Post subject: |
jakokombi wrote: |
The rear drain tubes on my '79 extend about 3" - 4" below the "gutter" rail ?, inside the air scoop area. I'm not sure yet where the water exits from the air scoop area. |
Was this a late bay change?...[/quote]
It must have been a change at some point. My knowledge is limited since I am only looking a my '79, My 22 year old son works at a shop, close by, that is doing a "restoration" on a '71 bay bus. It will show up in some of the VW magazines soon. A red and white, double slider with a sunroof and some other stuff. This bay bus has the rear drain tubes that run thru the horizontal battery tray on the passenger side and the same horizontal area on the drives side. |
HarryFD Samba Member
Joined: February 24, 2012 Posts: 751 Location: Portland, OR
Posted: Wed Jan 01, 2014 8:41 pm Post subject: |
makin' boost wrote: |
jakokombi wrote: |
My 1970 has the drain tubes pass through the engine room as well.
For the later bus in question I wonder if some one cut the tubes at some point as part of a "repair". _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300 |
SGKent Samba Member
Posted: Thu Jan 02, 2014 10:49 am Post subject: |
it isn't like a flood of water gets in there. If it is raining, water is coming in thru the air vents anyway so what has one accomplished by extending the tubes? A 1/2 gallon of rain water comes in thru the vents and a teaspoon thru the sunroof drain... |
Posted: Thu Jan 02, 2014 11:44 am Post subject: |
SGKent wrote: |
Very good point .............. Problem solved ................... |
type2much Samba Member
Joined: November 13, 2003 Posts: 319 Location: 65536 Missouri
Posted: Thu Apr 17, 2014 8:04 am Post subject: |
My cables are broken just like in this picture. Is this how they normally break? Can a casting like this be fixed? Maybe with JB weld?
_________________ Gnarly Goat Rancher |
Posted: Thu May 01, 2014 3:30 pm Post subject: |
type2much wrote: |
what are these "sunroof plates" and where do they go? |
I don't recognize those. I am fairly certain my 1977 bus does not have those, but I have not yet completely disassembled mine.
Posted: Thu May 01, 2014 3:31 pm Post subject: |
type2much wrote: |
My cables are broken just like in this picture. Is this how they normally break? Can a casting like this be fixed? Maybe with JB weld? |
I don't think JB Weld would be good for that repair. You might try brazing it, but even then I think that "potmetal" casting may not like it. Other folks may disagree. |
Posted: Sat May 31, 2014 7:19 pm Post subject: |
I have discovered that one of my front drain tubes is plugged and for the time being I do not have the time or energy to clear it. The roof appears to work (slides forward and back and pops up into position).
In the past, I had the gaps taped shut with metal tape the HVAC guys use to seal ductwork. It has worked well for the past 2 years but over time, it degrades and needs replacement.
Seeking a permanent solution to keep water out of my bus while not preventing me from attaining full operation in the future, I decided to do the following:
1-Remove the remnants of the Factory seal;
2-I got 20 feet of 7/64" Vacuum/Washer hose which seems to fill the gap tightly;
3-Using WD-40, I pressed the tubing into the gap to make a seal.
I will wait 2-3 days for the tubing to settle into position and then test with my garden hose. Hopefully, it will keep the water out.
Wish me luck. _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300 |
SGKent Samba Member
Posted: Sun Jun 01, 2014 10:12 am Post subject: |
the pieces in the photo are not for a bay
the tube needs to be cleaned from the bottom with a vacuum and a piece of copper wire. Do not use compressed air. The tube is inside the B pillar and near impossible to replace as it was installed when the B pillar was welded in. The tube is steel. It will and is rusting inside out. When it perforates the water will come out near the seats. Clearing it is the easiest job there is. Simply pull the lower plastic valve loose behind the front wheel and use a vacuum and wire to clean out the rust and mud that will be at the bottom as that is where it usually plugs up. Be gentle lest you break it since it will be thin from rust.
The original seals are available, or you can use 3 bug seals. |
Posted: Sun Jun 01, 2014 10:23 am Post subject: |
SGKent wrote: |
the pieces in the photo are not for a bay |
Which post is this note for?
Quote: |
the tube needs to be cleaned from the bottom with a vacuum and a piece of copper wire. Do not use compressed air. The tube is inside the B pillar and near impossible to replace as it was installed when the B pillar was welded in. The tube is steel. It will and is rusting inside out. When it perforates the water will come out near the seats. Clearing it is the easiest job there is. Simply pull the lower plastic valve loose behind the front wheel and use a vacuum and wire to clean out the rust and mud that will be at the bottom as that is where it usually plugs up. Be gentle lest you break it since it will be thin from rust. |
I can slip a rod or small tube from thee bottom all the way up to the double crimp but I cannot get past that point. If I go the other way, same thing.
I have a set of these (1 piece for a bus) but decided to save them for a working sunroof. The tubing only set me back under $10 and seemed like a cost effective alternative since the roof panel will not be moved until I resolve the drain issue. _________________ 1970 Deluxe Sunroof Bay Brilliant Blue/Cloud White
1973.5 911 Targa
2009 MB C300 |
