Cainepolo12 Samba Member
Joined: December 20, 2005 Posts: 27 Location: Nashville, TN
Posted: Mon Jan 20, 2014 2:21 pm Post subject: Need Transmission guidance |
After 10 years of sitting, I decided to rebuild my 1967 s042 hardtop. Ive rebuilt thee engine and everything is running great. I went to back it out... and nothing. Nothing in first or any gear. The car has been pushed in neutral but that is all the moving it has done.
Here's what I know-
The transmission worked when I put it in storage. In fact, it was great.
It feels as though it goes in and out of gears smoothly when shifting
There are no weird noises or strains
Any help would be greatly appreciated. Transmissions are totally foreign to me, but I can rebuild an engine, so I can tackle most things. I am not sure where to begin looking for the answer. Thanks in advance. |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Mon Jan 20, 2014 2:50 pm Post subject: |
it might be something inside the bellhousing that is off from sitting so long
I would pull the engine out and start there look at clutch, pressure plate, throw out bearing, the clutch cable and arm
also check the oil in the tranny maybe it leaked out and is not letting it go into gear _________________ '60 15 window walkthrough
why is there no sarcasism button on here? |
nice dad Samba Member
Joined: July 25, 2013 Posts: 317 Location: Honolulu, HI
Posted: Mon Jan 20, 2014 2:54 pm Post subject: |
How is your shift rod connection to the tranny?
You may be manipulating the stick shift thinking you are going into gears when you may not be. _________________ 1967 Single Cab |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4573 Location: St Charles, MO
Posted: Mon Jan 20, 2014 4:29 pm Post subject: |
I'm betting on the same thing, sounds like your shift rod connector is severed, no more gears until you replace it. Crawl underneath it, look at the connector just forward of the nose of the transmission. What does it look like? Grab the shift rod and wiggle it, or have someone in the cab (everything off, brakes set!) shift through the gears while you watch the connector. I'll bet you'll find it severed. The rubber center of the connector rots away and finally breaks.
Ask us how we know...
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Mon Jan 20, 2014 6:27 pm Post subject: |
Im going to crawl under tonight and check the connector. The clutch, pressure plate, etc are all new, but who knows. Thanks guys, I will let you know what I find. |
Posted: Tue Jan 21, 2014 7:19 am Post subject: |
Here is what I found. I believe this is the Shift Rod coupling. Everything looks to be ok. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Tue Jan 21, 2014 9:19 am Post subject: |
You say its a new clutch, could it be adjusted too tight, keeping the bus out of gear?
Did you have someone in the cab shifting gears while you watched underneath where your photo was taken? _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Tue Jan 21, 2014 9:53 am Post subject: |
I am going to pull the engine again today. I will check torque on the clutch. I cant imagine I wouldnt have torqued it properly but who knows. Should the motor be running when I shift through the gears? I am assuming NO, but I have been wrong before. I will shoot a video while i do that and see what happens. Also, going to drain and refill the tranny before anything else per another suggestion, |
Posted: Tue Jan 21, 2014 10:11 am Post subject: |
I just took a video from underneath while I shifted through gears and everything is moving as it should. I dont think there is a way to upload video here, but I am pretty sure everything is ok. This leads me to think that the clutch is too tight or the transmission is seized. What could I be missing? Draining and refilling tranny now. Thanks guys. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Tue Jan 21, 2014 10:15 am Post subject: |
i think we are not suggesting it is not torqued correctly, but rather the cable might need adjustment.
it is also possible that your clutch disk is sticking to the flywheel?
if it has been sitting for a long time this could easily have happened.
that could make shifting tricky _________________ regards
Uli
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Tue Jan 21, 2014 10:30 am Post subject: |
Clutch not adjusted correctly, wrong PP and TOB or the reverse gear collar has moved and the inputshaft has come apart. |
Stocknazi Samba Member
Posted: Tue Jan 21, 2014 4:10 pm Post subject: |
as long as the oil level is close to full and it's clean, there is no need to change _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Tue Jan 21, 2014 7:33 pm Post subject: |
It looks like the grub screw is loose next to the greasy boot. If that's not home it won't shift. Can you see if the rod going into the boot area is push/pull/twisting? |
Posted: Tue Jan 21, 2014 8:42 pm Post subject: |
The rod does push, pull and twist depending on which gear its in. I noticed the same thing and tried to tighten it, but it is cranked down. Also, I rolled the car in neutral and it rolls free. I put it in first and it stops. This leads me to believe it is clutch related. I am going to start with adjusting the clutch cable. If that doesnt do it ill drop the motor. Thanks again guys. |
BarryL Samba Member
Posted: Wed Jan 22, 2014 8:47 am Post subject: |
Cainepolo12 wrote: |
I rolled the car in neutral and it rolls free. I put it in first and it stops. |
That means it's normal. Are you saying if you start the engine in neutral, depress the clutch, put it in first, let up the clutch, and try to drive off, it won't connect the engine to the drive train? |
iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2041 Location: M*ssholia
Posted: Wed Jan 22, 2014 8:54 am Post subject: |
Whats happening at the nose cone?
with engine off you can crawl under there and make sure the shaft on the nose cone is moving. You can also remove the shift rod and move the shaft with a pair of vise-grips etc. |
demon1018 Samba Member
Joined: September 12, 2009 Posts: 930 Location: crystal river, fl
Posted: Wed Jan 22, 2014 6:20 pm Post subject: |
will it not shift into a gear when its running? but it does when its off? |
bro2539 Samba Member
Joined: May 03, 2004 Posts: 414 Location: fort worth, texas
Posted: Thu Jan 23, 2014 3:14 pm Post subject: |
have you checked to see if you have a stripped drum? If the splines are rounded off, it will keep it from moving. |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 970 Location: Ocean City > Boca > Pompano > Kirkland > Eugene
Posted: Sat Apr 19, 2014 8:04 am Post subject: |
I am just reading this today, and now I am curious what the issue was? _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
Single carbs are for lawn mowers! |
Don't forget those seat-belts!
Click to view image |
bluebeetle63 Samba Member
Joined: December 04, 2012 Posts: 47 Location: Miramonte, Ca.
Posted: Sat Apr 19, 2014 7:21 pm Post subject: |
try this if you have the engine out, it may help narrow down the problem. put the disk on the main shaft in the tranny housing, have someone throw it into first and hold it there, then you turn the disk clockwise. While your back there listen for any strange noises and feel for anything weird in the shaft while your turning the disk, the bus should move. Try all the gears. One other thing you can disconnect the shift rod when the tranny is in neutral, grab the shift fork in the nose cone wiggle and move it, feel for something odd, say it spins in a full circle with no resistance you know your fork broke. _________________ The time will come when we as a people rise above and free ourselves from the oppression of the most cruel establishment ever known. The Department of Motor Vehicles. |
