What did you do to your Bug Today?
Page: Previous  1, 2, 3 ... 280, 281, 282 ... 447, 448, 449  Next
joeyk803c
joeyk803c is offline
PostPosted: Fri Apr 18, 2014 9:19 pm    Post subject: Reply with quote
Motor drop didn't go as planned today, but I did replace the trunk latches. Now I can open the "trunk" from outside the car, and not have to use vice-grips locked onto the latch cable.
Also tightened up the E-brakes, still having a hard time with those damn drum brakes.
Last, but not least... Did this. I really, really disliked the stock battery location. To far away from the fuse block, and under a seat with metal rods and springs, a potential short and fire waiting to happen. I don't ever plan on using the rear space behind the rear seat for cargo space, so the battery and fuse block will go on the left side, a 10" sub and amp, on the right (eventually). Battery will sit in a tray of angle iron, which will be bolted to some 1/4" plate tabs welded to the floor. ATO fuses are easy to find, and can be used across multiple-vehicles, (a plus for me). This is just mock up for now, battery position may move.
marklock
marklock is offline
PostPosted: Sat Apr 19, 2014 1:45 pm    Post subject: Reply with quote
It's been a long winter. Finally got the battery charged and added fresh fuel. Going to fire her up shortly, first time since Fall.
1968 Beetle project
Globespotter
Globespotter is offline
PostPosted: Sun Apr 20, 2014 8:59 am    Post subject: Reply with quote
Took the Bug out for a drive on the back roads yesterday then got her up to 70 - felt pretty good!
1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
1971 SB Survivor Story: https://globespotter.com/
Road Trip Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=511800&highlight=
My 77 Westy Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=647114&highlight=
http://vw-mplate.com/mcode.php?lang=EN&id=30990
https://vw-type2-id.xyz/mplate/72067382
Mikedrevguy
Mikedrevguy is offline
PostPosted: Tue Apr 22, 2014 2:19 pm    Post subject: Reply with quote
Picked up super street tranny from Strictly Foreign. Pulled current tyranny .
PSA: remember, alway disconnect the tranny from shift coupler under the seat. The more you know.
Swapping all the mounts, straps, and ground strap, etc, cleaned all the oil off the rear tyranny mount - replaced the leaky main seal earler.
Was grateful the bolts for the cv joints behaved themselves.
Cut access ports in the rear wheel wells to have better access to the carbs.
Two weeks up and running? Let's hope.
74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!!
AlienJohn
AlienJohn is offline
PostPosted: Fri Apr 25, 2014 6:46 am    Post subject: Reply with quote
Installed new door seals, trunk seal, rear deck seal,
replaced and adjusted a brake cylinder, installed new
rubber beading on all fenders, went for a ride, waved at people,
its been a good day.
JB in Ohio
All Hail Snorkelstang !
72 Standard Beetle
74 Karmann Ghia Coupe
76 Fender Telecaster
85burb
85burb is offline
PostPosted: Sat Apr 26, 2014 6:37 pm    Post subject: Reply with quote
Installed a few crappy parts from cip1. A "top quality" antenna that was a pos. a nice looking oil pressure sender. a good trunk latch. and nice set of lap belts. I had ordered some lock pulls and only got the collar that goes in the door. they did not send the actual pull part. Will not order from them again. and fixed my lights...again. spent most of the day looking for 11 inch wipers and a horn. hope to pass safety inspection later this week and make it my daily driver. cant wait. it has been over 6 years that I have not drove a bug daily.
volkz
volkz is offline
PostPosted: Sat Apr 26, 2014 6:58 pm    Post subject: Reply with quote
did its spring tune up. good to go for a summers worth of cruising
1968 beetle
1970 beetle
bloomerific
bloomerific is offline
PostPosted: Sun Apr 27, 2014 5:44 pm    Post subject: Reply with quote
(I'm brand new, by the way, hello)
I ripped off the top & headliner down to the frame, and put the window in my living room. Smile
Now to actually get it running and on the road...
Hnoroian
Hnoroian is offline
PostPosted: Tue Apr 29, 2014 12:31 am    Post subject: Reply with quote
Packed the front wheel bearings, adjusted the brakes, washed, waxed and polished the bloody knuckles Very Happy also bought a spare throttle cable, clutch cable, wing nut, and spare belt;all of which I hope I don't have to use on the trip to the beach this next week...
Stupid people do stupid things.
Hnoroian
Hnoroian is offline
PostPosted: Tue Apr 29, 2014 12:39 am    Post subject: Reply with quote
For your wipers, go buy a good 24" wiper blade refill and cut it in half with a pair of side cutters (measure first, 24" are actually like 23"). Keep your old housing and install the newly cut refills in the old arms. I did this years ago and saved me a lot of time and money finding 11" blades. Good luck getting your car inspected...
85burb
85burb is offline
PostPosted: Wed Apr 30, 2014 4:23 am    Post subject: Reply with quote
Well it passed inspection yesterday! Now it's my daily driver. If I would have had old wipers to rebuild I would have done that's that's a good idea. Thanks!
plimthing
plimthing is offline
PostPosted: Thu May 01, 2014 5:52 am    Post subject: Reply with quote
I installed new speakers in the rear and two new smaller ones in the front doors. Tomorrow i will tidy up wiring and vacuum the carpets and install all seats. Then, if the sun is shining i will go for a whiz around with the roof down, radio on!
AlienJohn
PostPosted: Thu May 01, 2014 6:02 am    Post subject: Reply with quote
It's almost summer, so naturally I am working on the heater and defrost tubing so I can make the car hotter Smile
JB
72 Standard Beetle
plimthing
PostPosted: Thu May 01, 2014 11:14 pm    Post subject: Reply with quote
went for spin, goes nice, stereo sounds great from 4 speakers now!
Finding it hard to tune carb as per instructions on resource. I think it may have an air leak somewhere, not sure how old carb is but maybe time for a new one? Might try the rev and hand over throat trick to see if it clears itself. So frustrating when the end is in sight.....
drgerry
drgerry is offline
PostPosted: Fri May 02, 2014 9:58 am    Post subject: clean engine Reply with quote
organized and cleaned the engine. Looks better.
t7d5
t7d5 is offline
PostPosted: Fri May 02, 2014 10:47 am    Post subject: 11 inch wipers Reply with quote
Advance auto carries the wipers and a few other beetle stuff.
tommyangleterre
tommyangleterre is offline
PostPosted: Sat May 03, 2014 8:26 am    Post subject: Reply with quote
just removed my 1915cc to take off my trany...I am going with 3.88....free fyer+ super diff!!!
[/img]
joeyk803c
PostPosted: Sat May 03, 2014 12:10 pm    Post subject: Reply with quote
Started cleaning it out. Going to start working on running the wiring today from the motor to the fuse block for now. then from the front end to the fuse block.
mountainkowboy
mountainkowboy is offline
PostPosted: Sat May 03, 2014 12:48 pm    Post subject: Reply with quote
Got the engine back in and am having a throttle cable issue. Will get to the bottom of it early in the week.
Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater"
bloomerific
PostPosted: Sat May 03, 2014 4:41 pm    Post subject: Reply with quote
I put my finger through the back seat left floor pan. Smile Just wanted to see that happen before I replace them. I was mildly amused. Also tried to start it again, no dice. Thank goodness she's going to the hospital on Monday.
Page 281 of 449
