lyrikz Samba Member
Joined: September 12, 2011 Posts: 249 Location: Seattle, WA
Posted: Mon Apr 21, 2014 8:05 pm Post subject: Epoxy paint is not drying? |
Omni epoxy paint. Correct mixing ratios, letting it sit the correct amount of time. I come back 24 hours later and you can still stick a finger nail in it.. Do i just need to give it some more time? It was only 60 degrees or so outside.
Thanks. |
Matt K. Paint and Body Nutcase
Joined: January 14, 2005 Posts: 2598 Location: Hemet, So Cal.
Posted: Mon Apr 21, 2014 8:14 pm Post subject: |
60 degrees is very cool for a catalyzed product to be completely "Hardened" overnight.....it may take a little longer depending on your "Flash Times" between coats.....the amount of material put on in a single coat Etc.......if you are going to have some sun in the next few days try letting it have some and see if that helps cure it up. _________________ This is my 23rd year in the Auto Body/Paint Game!
*Take a look at some of my custom paint: http://s110.photobucket.com/albums/n119/mrpaint_2006/ .( NOTE: these are some older jobs but still neat.) |
UreKem Paints Samba Member
Joined: March 23, 2014 Posts: 26 Location: Perkinston, Mississippi
Posted: Mon Apr 21, 2014 9:13 pm Post subject: |
Epoxy cure slows exponentially as the temp decreases. It may just need a little more time. Was it very humid or raining? Some epoxys are subject to amine blush in the presence of moisture which slows the cure a lot. _________________ Visit www.thecoatingstore.com for quality UreKem automotive Paints. |
lyrikz Samba Member
Posted: Tue Apr 22, 2014 8:56 am Post subject: |
UreKem Paints wrote: |
Epoxy cure slows exponentially as the temp decreases. It may just need a little more time. Was it very humid or raining? Some epoxys are subject to amine blush in the presence of moisture which slows the cure a lot. |
Ok, makes sense. Last few times i used it was in summer. 80 degrees and dry...
It was i believe 60 when i painted... and i put it on a bit thick...
I do have a pic i will send your guys way here in a bit.
Now, im a novice at body work, i have done a few cars, i had zero faith i was going to get this hood straight. It looked like someone took a hammer to the whole thing. I got most of the metal as straight as possible, then put some filler and it looks good. i still have a few hours left on this piece though. its coming along nicely.
