New starter/extra wire
richardsvdubs
richardsvdubs is offline
PostPosted: Tue Apr 22, 2014 10:08 am    Post subject: New starter/extra wire Reply with quote
I have a 69 bus. Bought new starter. It has one male connector. The old one had multiple connectors. There is one wire going toward the front of the bus. Small gage. Any ideas what to do with this or what it is for? Embarassed
Red Fau Veh
Red Fau Veh is offline
PostPosted: Tue Apr 22, 2014 10:11 am    Post subject: Reply with quote
You need a manual for a bus! But it is an easy goody to hook up, that wire you have, is it red?
1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote:
Swivel Seat panels are for people with no friends Crying or Very sad
richardsvdubs
PostPosted: Tue Apr 22, 2014 10:24 am    Post subject: Reply with quote
It is solid white.
1967250s
1967250s is offline
PostPosted: Tue Apr 22, 2014 10:53 am    Post subject: Reply with quote
Sounds like a mod or replacement. The wire from the starter switch to the solenoid should be a @12 gauge/ largish red wire. Look under your dash and find where it goes. There are free wiring diagrams up in the technical section.
Wildthings
Wildthings is offline
PostPosted: Tue Apr 22, 2014 8:04 pm    Post subject: Reply with quote
Where does your white wire go? About the only thing I can think that someone would add to the #50 circuit would be some kind of alarm device, or maybe a bypass for an added external ignition ballast resister.
