craigsp51 Samba Member
Joined: December 29, 2013 Posts: 2 Location: Lakeland Florida
Posted: Sun Mar 23, 2014 8:22 am Post subject: front disc brakes |
Is there a conversion available for the Thing to front disc brakes? |
hobie16 Samba Member
Posted: Sun Mar 23, 2014 11:24 am Post subject: |
Yes. _________________ Don't be fooled by appearances. In Hawaii, some of the most powerful people look like bums and stuntmen.
--- Matt King
If anything’s going to happen, it’s going to happen out there.
---Captain Ron |
Vw_thing_73 Samba Member
Joined: March 23, 2014 Posts: 3 Location: High point nc
Posted: Sun Mar 23, 2014 11:34 am Post subject: |
Jbugs.com has em. |
63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Sun Mar 23, 2014 2:32 pm Post subject: |
got mine from SoCal. AC industries
various thoughts out there. just installed mine. direct bolt on kit. easy installation. will need 15" rims though.
should be others out there that will fit stock but may be higher end of cost.
there are some other vw models that you can get parts from. I believe Ghia is one. some others here on site more knowledgeable on cross over parts.
so far like mine but very limited drive time since installation. |
cecil Samba Member
Joined: February 23, 2005 Posts: 461 Location: Stockton, CA
Posted: Sun Mar 23, 2014 8:24 pm Post subject: |
Had mine for ~10,000 miles, work well. From So. Cal. _________________ I may not be that funny or athletic or good looking or smart or talented....I forgot where I was going with this
I have this wierd desease called "must tear everything up and put it back together when there's nothing wrong with it...Itus." |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
strelnik Samba Member
Joined: October 01, 2010 Posts: 352 Location: Michigan
Posted: Tue Mar 25, 2014 7:00 am Post subject: |
63ziggy wrote: |
Since 15" rims are needed for a disc-brake equipped Thing, which type of 15" rims? I understand that the various VW models with 15" rims have different offsets and widths.
Can anyone enlighten me?
Thanks _________________ L'audace! L'audace! Toujours l'audace! |
FV195 Samba Member
Joined: February 19, 2005 Posts: 480 Location: carlisile, pa
Posted: Tue Mar 25, 2014 8:30 am Post subject: |
Discs are in my future, I have a set of 15x4 bettle steelies and 15x6 centerline copies, my 14" stock wheels will be up for sale soon. Looked at jugs. Com no thing discs avaible? Will probably use AC ind set up |
cecil Samba Member
Posted: Tue Mar 25, 2014 9:10 am Post subject: |
CSP (piersideparts.net) has disc brakes for 14" wheels. Check with your bank about a loan to buy them. _________________ I may not be that funny or athletic or good looking or smart or talented....I forgot where I was going with this
FV195 Samba Member
Posted: Tue Apr 01, 2014 7:39 pm Post subject: |
Rear bearing done, test drive brakes bad, worked just need adjusted. Pushed me over the edge, discs will be ordered soon (with in the next week) install updates will be posted, look forward to stopping better |
IBTHING Samba Member
Joined: May 05, 2011 Posts: 9 Location: IMPERIAL BEACH, CA
Posted: Tue Apr 15, 2014 9:18 pm Post subject: DISC BRAKES |
I have a 74 and have put EMPI disc brakes all the way around...best thing I have done...Hot VW magazine is a good resource for Thing parts...there are many available...
saddlesore1 Samba Member
Posted: Tue Apr 22, 2014 3:43 pm Post subject: |
I have vacillated over this issue for over a year and pulled the trigger yesterday on a set of AC disc brakes. I had them drill rotors out to 14mm studs for my BTR's. I hope they are all they say they are. I will post the progress on my build page. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Tue Apr 22, 2014 5:55 pm Post subject: |
I recently installed the CSP brake kit. It is designed to be used with the stock 181 steel wheels. (I prefer the look of the stock wheels)
The components are very nice quality, and the installation was quick and easy with no snags. The front brakes are part of a work in progress, so I'll post additional info and photos as the project progresses.
oasis Samba Member
Posted: Wed Apr 23, 2014 6:03 am Post subject: |
mondshine wrote: |
I recently installed the CSP brake kit. It is designed to be used with the stock 181 steel wheels. (I prefer the look of the stock wheels) |
Very nice. I figured the CSP set-up was nice because I had their shifter in my Super, and it was great.
A part of me wishes I had spent the extra dough. (Maybe, I'll swap front brakes again once I have done the other major projects. Technically, I'm a week and a half away from swapping them for the first time.) _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
surfarii Samba Member
Joined: November 26, 2006 Posts: 307 Location: Hawaii
Posted: Wed Apr 23, 2014 4:17 pm Post subject: |
mondshine wrote: |
They look very nice Mondshine. Thanks for posting
Can 14mm studs be pressed into them? The only option for the AC industries product is to have the screw and glue type studs. Not My 1st choice but my only choice since I cheaped out and went the AC way.
As little as I drive mine I couldnt justify the 4X price. |
Posted: Wed Apr 23, 2014 7:26 pm Post subject: |
The 14x1.5 lugs are threaded into the hubs on the CSP brakes. You can't see it in the photo I posted, but the hub is about 3/4" thick where the studs are located. The instructions warn against removing them; they are "loctited" in place. I am confident (for now) that they will stay put, provided they are properly torqued; I always use a torque wrench on wheel lugs.
Yes, the CSP brakes are a little expensive, but I have justified the expense (maybe rationalized would be more accurate) because I take some long drives in the Thing, and brakes are in the top three... Stereo, Steering, Stopping |
