Judson 36hp running hot
ragtop62
ragtop62 is offline
PostPosted: Wed Jun 11, 2014 3:39 pm    Post subject: Judson 36hp running hot Reply with quote
hi everybody/anybody!!
I need help please... Judson 36hp is running hot - similar to thread posted - 10 to 20 mins runs OK then engine loses power - allow to cool - engine runs again for approx another 10 - 15 mins loses power.
Unit reconditioned approx 800 miles ago by Alejandro.
Receives correct amount of lubrication.
Tension of belts correct.
Stronger fuel pump spring fitted.
Correct fuel jets
Engine itself runs cool - points, tappets and timing all correct.
Charger not noisy, just slight tick at idle but disappears
New 6v coil fitted.
Charger housing hot to touch (can place hand on housing for only a couple of seconds max).
Condensation appears on carb when charger housing hot but not on manifold neck.
I'm running out of options - going to replace spark plugs, plug leads and check carb for any blockages etc
Please, please can anyone advise
vwhelmot
vwhelmot is offline
PostPosted: Thu Jun 12, 2014 8:54 am    Post subject: Reply with quote
Check fuel pressure, check timing (makes a huge difference) , check pump push rod isn't stiff.
Any noise issues when it happens, any pinking?
avus
avus is offline
PostPosted: Thu Jun 12, 2014 9:08 am    Post subject: Re: Judson 36hp running hot Reply with quote
Correct fuel jets
New 6v coil fitted.
Is this a fresh engine, too?
ragtop62
ragtop62 is offline
PostPosted: Thu Jun 12, 2014 12:49 pm    Post subject: Re: Judson 36hp running hot Reply with quote
Correct fuel jets
New 6v coil fitted.
thanks for replies
Engine good - no end float etc - good barrels and pistons etc.
fuel pump got stronger spring in it - but will check push rod if thats what you mean - how would i check fuel pressure ? timing is fine but will check and check again haha no pinking tappets spot on
going to strip carb this weekend - thinking it could be fuel starvation maybe ???? but clutching at straws
avus
avus is offline
PostPosted: Thu Jun 12, 2014 1:14 pm    Post subject: Re: Judson 36hp running hot Reply with quote
I had a problem with new piston/cyls on my Judson engine, due to insufficient piston ring end gap causing a "soft seizure" loss of power when hot.
ragtop62
ragtop62 is offline
PostPosted: Thu Jun 12, 2014 1:53 pm    Post subject: Re: Judson 36hp running hot Reply with quote
interesting - thanks avus - will check for compression - not much smoke if any on start up
Cheers
vwhelmot
vwhelmot is offline
PostPosted: Fri Jun 13, 2014 8:20 am    Post subject: Reply with quote
I fitted a fuel pressure gauge in line from the outlet to the carb just to check the pressure. Should be around 2 psi.
D-train
D-train is offline
PostPosted: Sat Jun 14, 2014 3:17 am    Post subject: Reply with quote
what about under load? still 2 psi?
shiny paint doesnt make it worth any more
ragtop62
ragtop62 is offline
PostPosted: Sun Jun 15, 2014 11:57 am    Post subject: Reply with quote
I've loosened tension on supercharger belts - I think it as made some difference !
hopefully deck lid standoff will be here this week so another form of cooling.
Timing ok
retroman
retroman is offline
PostPosted: Sun Jun 15, 2014 12:14 pm    Post subject: Reply with quote
Check if the intake air to the fan could be getting blocked. Possibly the fiberboard in front of shroud. If loose it can cause intermittent blockage and overheating.
1967 bug recovering from a PO
1987 Vanagon Wolfsburg Weekender "Otto" been all over the place with never a problem!
ragtop62
ragtop62 is offline
PostPosted: Sun Jun 15, 2014 12:19 pm    Post subject: Reply with quote
cheers for the idea - fiberboard fixed in place - fram oil cooler coil would stop it in front of shroud
NUG637
NUG637 is offline
PostPosted: Mon Jun 16, 2014 2:28 pm    Post subject: Reply with quote
had a very similar thing on mr okrasa engine when i first put it in the car… could drive beautifully for 20 minutes them boom…. no power…. couldn't get it to start etc until it was dead cold…. had me on the side of the road half a dozen times…. then i found the power to the reg was barely connected…. fixed that and never had an issue ever since… maybe worth checking?
vwkever68
vwkever68 is offline
PostPosted: Fri Jun 20, 2014 8:53 am    Post subject: Reply with quote
Did you measure the temprature of the Judson ? I also have one from aljandro and when I am accelarating a lot the Judson can get 110C (230F). But when I'am driving at constant speed, It will stay around the 60C - 80C (140F - 176F).
I don't loose any power with those tempatures.
Does your engine runs well without the supercharger?
snowbug
snowbug is offline
PostPosted: Sat Jun 21, 2014 12:21 pm    Post subject: Re: Judson 36hp running hot Reply with quote
Correct fuel jets
New 6v coil fitted.
Had the same sort of problem with my zwitter. Stock 40hp engine. Could drive normal for 1/2 hour then die. Turned out to be a little piece of shite in the fuel valve. I rebuilt the valve , put in a new tank and blew out the line. Jim
ragtop62
ragtop62 is offline
PostPosted: Sat Jun 28, 2014 11:15 am    Post subject: Reply with quote
I think I have sorted it (hopefully)
Manifold stud in cylinder head - threads had stripped - air leak ! - studs replaced - much tighter fit now.
Tension pulley for supercharger - did run really hot - turned out that the bearings were knackered - replaced with cooler running bearings - tension pulley does not even get warm now.
Engine runs better than it ever has.....so hopefully problem solved.......!!!!????
Can I just say a big, big thank you for all comments and ideas.
Andrew
vwhelmot
vwhelmot is offline
PostPosted: Sun Jun 29, 2014 1:45 am    Post subject: Reply with quote
It's good to find the solution to the problem ain't it!!
ragtop62
ragtop62 is offline
PostPosted: Sun Jun 29, 2014 2:39 am    Post subject: Reply with quote
it sure is..... fingers crossed the bug will be ok to run to Spa in August !
Cheers again
