87RedWesty Samba Member
Posted: Sat Jul 05, 2014 10:55 am Post subject: Getting wiring behind the Westy cabinets |
I've got an 87 Westy, and recently installed a Propex and a gas detector under the back seat. At this point they're just wired up into an extension of the wiring of the galley light (which, because I installed the GW auxiliary battery kit, is fed off the wire that runs from the battery under the driver's seat to the nest or wires at the under dash fuse box). But this current wiring isn't ideal, and I'd like to put them on their own circuits. So I'm installing a Blue Sea fuse box on the cabinet behind the driver's seat. The question is how to get the wiring from under the back seat up to the back of the driver's seat. I figured that if I pull the refrigerator, I can easily pass it behind the back of the cabinet. But pulling the fridge wasn't on my list of desired things to do. Is there any way to run the wires without pulling the fridge? I tried wiggling a coat hanger back there and it didn't seem to get me anywhere.
(For Bonus Points: I've thought of taking the red wires out of the little existing two-fuse box on the wall behind the driver's seat, and using the new fuse box for them instead. The smaller wire seems to come directly from the battery, so that makes sense. But the fatter wire comes from a relay under the seat, so I figure I should leave it alone. And comments on these?)
Thanks! |
adamjjohn203 Samba Member
Joined: March 18, 2012 Posts: 187 Location: Bainbridge Island, WA
Posted: Sat Jul 05, 2014 11:19 am Post subject: |
Just pull the front panel off the fridge, the lower grille below the fridge is attached to that. It would probably be easier to run the wire with your hand under there. _________________ '87 Westfalia
2000 Volvo V70 "eVOLVOd" |
Westified Samba Member
Posted: Sat Jul 05, 2014 1:58 pm Post subject: |
You can also remove the city water inlet on the side of the van. Look in there, you may be able to pass a wire behind the fridge that way. You should probably get a fish tape to pull the wire. Just make sure it doesn't rest against any hot part of the fridge if you still have your propane fridge. _________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
Posted: Sat Jul 05, 2014 2:05 pm Post subject: |
Here is a picture with the fridge removed. Hope it helps.
Captjon1959 Samba Member
Joined: October 11, 2010 Posts: 287 Location: Peoria, Illinois
Posted: Sat Jul 05, 2014 3:27 pm Post subject: |
You said you don't want to remove stuff, but when you do here's what I did to pass wires.
_________________ 1984 Westfalia Wolfsburg Edition
Former 1.9 L now Bostig Ford Zetec |
Posted: Sun Jul 06, 2014 7:00 pm Post subject: |
As Westified suggested, I pulled the outside city water hookup loose and managed to push a coat hanger (a poor person's fish tape) behind the insulation and up front to where I could grab it through the hole where the water pipes come in under the sink. It didn't work from there to fish around for the back exit (where the piping comes through the wall under the horizontal cabinet doors), so I pulled loose the other water hookup and managed from there. Fairly simple, actually, and much easier than pulling the fridge. Thanks for everyone's help. My wiring will be safer now, making me less a candidate for posting pictures of a burned up van. |
Timwhy Samba Member
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Mon Jul 07, 2014 5:00 am Post subject: |
I usually go with the big zip tie approach as well. I keep a couple 48" long zip ties tucked away behind the rear seat so I know where they are when a new project comes up.
I use a small carbide bit in my Dremel tool to make a 1" slot in the end of the cable tie that allows me to pass the electrical tape through before I tape the wire to it. This will allow you to pull wires without the annoyance of the tape sliding off and leaving your wire half way along your intended wiring path. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
chojinchef Samba Member
Joined: February 17, 2011 Posts: 1539 Location: Central Massachusetts
Posted: Mon Jul 07, 2014 5:33 am Post subject: |
I ran wires behind when I had cabinets off. Recently needed to run additional wires for MIL light and Oil warning lights. I used a typical wiring tape used by electricians. When I did, I also pulled a piece of nylon twine through, so next time I pull a wire, I have the twine to do it. Just need to remember to always pull a new piece of twine through and you are set for the life of your van. _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
dcaver01 Samba Member
Joined: February 23, 2009 Posts: 103 Location: Los Angeles
Posted: Wed Dec 30, 2020 11:19 am Post subject: Re: Getting wiring behind the Westy cabinets |
Wondering how this has worked out for you all with running wires behind the fridge? Any issues ?
Is there any concern about the heat from the refrigerator LP exhaust? I know that flue get's pretty hot and don't want to melt any wires I run back there. I'll be running some 4 gauge battery cables along with a 3 other wires. |
Timwhy Samba Member
Posted: Wed Dec 30, 2020 12:05 pm Post subject: Re: Getting wiring behind the Westy cabinets |
dcaver01 wrote: |
When I had my fridge out to service it all the wires that I ran were intact and laying flat on the floor.
Probably if you leave some slack in your cables they will be flat on the floor as well. _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
Posted: Wed Dec 30, 2020 2:05 pm Post subject: Re: Getting wiring behind the Westy cabinets |
Timwhy wrote: |
dcaver01 wrote: |
Probably if you leave some slack in your cables they will be flat on the floor as well. |
Thanks Timwhy for the reply. Glad to hear that the wires should be safe. I'll be sure to leave some slack so they lay flat on the floor.
Here's some photos of the wiring on mine - just waiting on the new AGM batteries to arrive to finish up the install.
Running the wires from front to back was relatively easy, running the wires from back to front was a little more of a challenge and required some patience. |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Wed Dec 30, 2020 3:07 pm Post subject: Re: Getting wiring behind the Westy cabinets |
DanHoug did this, I'd assume it would keep anything from getting too hot? Not exactly why he did it, but I am going to next time I've got mine out. Seems like a great thing to do for a variety of reasons.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9445702
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Vanagon Nut Samba Member
Posted: Wed Dec 30, 2020 7:07 pm Post subject: Re: Getting wiring behind the Westy cabinets |
dcaver01 wrote: |
When I had my Dometic, it did not heat damage OE or added wires behind it.
The combustion box gets pretty hot too. If I recall, the 110VAC 14/2 wire typically gets routed behind the lip at rear opening of cabinet. The Dometic combustion box sits pretty low too.
Looking at Dans' images, distance from manifold face where it secures to body, and exhaust-combustion chamber looks like ~ 5". I'd guess there's at least 4" between wires and fridge heat sources.
A tape measure will tell all !
1988 West DIY 50º ABA
VE7TBN |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1889 Location: Montreal
Posted: Thu Dec 31, 2020 6:58 am Post subject: Re: Getting wiring behind the Westy cabinets |
See the water hose to the faucet in Westfield's photo.
I replaced my water hose by attaching a new one to the grungy old one and pulled it through.
I'm sure you could attach some wires to a new hose and pull it all through |
