wrc7687 Samba Member
Posted: Sun Mar 27, 2011 12:40 pm Post subject: Brake,clutch pedal assembly frozen ? |
Ijust got this 74 thing and the pedal assembly is frozen both the clutch, the brake will go in but not come out on its own the accelartor cable also feels like it is binding. the clutch will not move at all
before I start tearing apart thought maybe some could offer some clues or advice
thanks |
Semper_Dad Samba Member
Posted: Sun Mar 27, 2011 4:09 pm Post subject: |
How deep was this thing sitting in the mud? You could have a lot of rust on the clutch and throttle cables, along with the entire brake system being a corroded mess. |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Mon Mar 28, 2011 7:53 am Post subject: |
Once you get it out you should be able to work the pedals free.
Once that is done readjust or install a new spring.
part #131721163 _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
Posted: Tue Mar 29, 2011 2:16 am Post subject: pedal assembly frozen |
removed pedal assembly clutch frozen tried to free but cant guess I need new assembly
thanks
After removing the assembly clutch cable is in the tunel how can I retreive it? |
dan bateman Samba Member
Joined: December 01, 2009 Posts: 27 Location: minford ohio
Posted: Tue Mar 29, 2011 5:27 am Post subject: brake pedal assembly |
just did this repair. heat and master blaster will unfreeze pedal. cable remove driver side rear tire, clutch cable is on clutch lever with wing nut clean threads loosen wing nut or take off push cable forward should see cable in tunnel hole by where you took of clutch assembly dan bateman . |
Emeritusx Samba Member
Joined: June 20, 2008 Posts: 2775 Location: 12 inches behind the wheel
Posted: Tue Mar 29, 2011 7:08 am Post subject: |
My thing was the same way.. Just replace it, it is easy. Then park so the water pools in the rear (keep your front tires higher that back).. The pan holds the water for years and the pedal just sits in it til it looks like something from the titanic.. |
Posted: Tue Mar 29, 2011 8:06 am Post subject: |
you might get lucky if you block the transmission clutch arm and try to hook the cable as you manipulate the assembly back in
I use pb blaster for soaking parts. _________________ Michael Basso
CALL 518 630 0173 |
Westys' Dad Samba Member
Joined: March 01, 2012 Posts: 12 Location: Mid Missouri
Posted: Thu Jul 17, 2014 7:25 pm Post subject: return spring?? |
What is this return spring you speak of? My pedal flopped back toward the seat on the floor. Checked the cable and it had come unhooked. Removed the assembly, slacked the cable from the rear, and re hooked it and re mounted the pedal assembly, only to have it flop right back to the floor!!
Any ideas?
Thanks!
This is a 74 thing if that matters. |
Posted: Thu Jul 17, 2014 9:19 pm Post subject: |
There is supposed to be a spring wound around the clutch release arm that keeps tension on the clutch cable. |
Posted: Fri Jul 18, 2014 4:34 am Post subject: |
Semper_Dad wrote: |
There is also a stop plate bolted to the floor. Review the parts manual. Items 18 through 21.
How does that stop plate keep it from flipping toward the seat? It's mounted behind the pedal right? |
Posted: Fri Jul 18, 2014 5:31 am Post subject: |
Well regardless of HOW it works, I suppose that's my issue. There is a weak patch in the floor right where that stop is mounted and it has become useless. The patch ripped and is lower than it normally should be, letting the clutch pedal slide on by. Looks like welding is my fix! |
