Suboval Samba Member
Posted: Thu Jun 22, 2006 4:20 pm Post subject: 383 Bosch Distributor caps |
What's the difference (associated years, applications) between the black cap and brown one?
Also, the black cap and the brown cap on the left each have a notch on the bottom lip (to the left of the half circle for the condenser). But the brown cap on the right doesn't. What's it for?
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Thu Jun 22, 2006 5:11 pm Post subject: Re: 383 Bosch Distributor caps |
Suboval wrote: |
The cap pictured in the center is a replacement for Pre '48 VWs. The raised finger for the coil wire is the giveaway. _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9359 Location: Northwood, NH USA
Posted: Thu Jun 22, 2006 5:20 pm Post subject: |
Never seen 2 different height ones. I have a whole box of them, I'll have to check, but I think they are all the same height.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Thu Jun 22, 2006 5:34 pm Post subject: Re: 383 Bosch Distributor caps |
RareAir wrote: |
Suboval wrote: |
The cap pictured in the center is a replacement for Pre '48 VWs. The raised finger for the coil wire is the giveaway. |
Pre-48 only? Are the distributor wires different (low resistence) Pre-48? Did they change in 49 to a higher restance? The "raised finger" is a resistor ~ 10.2 kOHMS. So wouldn't that also be used for ignition noise suppression for cars that had radios? |
Posted: Thu Jun 22, 2006 5:36 pm Post subject: |
johnshenry wrote: |
Never seen 2 different height ones. I have a whole box of them, I'll have to check, but I think they are all the same height.... |
The angle that the picture was taken is deceiving. Both Bosch brown caps are the same height. The black one is taller due to the "raised finger'. |
Posted: Thu Jun 22, 2006 7:54 pm Post subject: |
Suboval wrote: |
johnshenry wrote: |
Ok, make sense.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
franklinunes Samba Member
Posted: Thu Jan 26, 2012 3:06 pm Post subject: |
Hello once again.
Can anyone help me identify this Cap distributor, it was in box in the shelf including a dismantled 383 distributor 5G.
I never saw it i and I cant find anything like this in the forum, so I ask kindly if anyone saw this one.
there is only the top flat cap, is missing the "body" cap .
Regards
Frank |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Fri Jan 27, 2012 8:36 pm Post subject: |
I can't make out the badge numbers but 5G would be a May 1951 distributor. The cap on the left does not appear as typical for VW while the one on the right does.
Not sure why some caps have that little notch and others do not.
Only other tid bit I can ad is that it was not unusual for the caps to have mismatched colors. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Fri Jan 27, 2012 8:41 pm Post subject: |
Non VW distributors used a flat cap also is it's probably for another car.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jan 28, 2012 4:55 am Post subject: |
tasb wrote: |
Only other tid bit I can ad is that it was not unusual for the caps to have mismatched colors. |
Hi thanks for the reply, both distributers are VW VE 4 BRS 383, one is 5G the one with that "different" flat cap, the other is 10F oct 50, and is with correct cap for split.
The other maybe is replacement later part, just was curious about it
Quote: |
Non VW distributors used a flat cap also is it's probably for another car. |
yes maybe is that, I was just curious was mixed with this 2 distributers, the most strange I need a 52 distributer and I have 2 which are early
Maybe the one 52 got broken and the guy in the past got 1 complete and the other to use has spare parts if needed, never know, whatever I will use it.
Regards and thats for the help
Frank |
Posted: Sat Jan 28, 2012 9:53 am Post subject: |
I frequently see these 383 distributors with the short Garbe Lahmeyer "VW" caps. They do fit but are incorrect application. _________________ Roads Scholar &
Posted: Sat Jan 28, 2012 10:12 am Post subject: |
tasb wrote: |
I frequently see these 383 distributors with the short Garbe Lahmeyer "VW" caps. They do fit but are incorrect application. |
Yes I see is wrong, I will use the correct one, in the past everything was great to use when the original parts were missing .
Thanks |
RobT Samba Member
Posted: Sat May 26, 2012 8:19 am Post subject: |
I'm trying to determine the age and app. of the cap on the left. It is shown with a normal 383 side exit cap. It does fit the 383 distributor perfectly however the inside is about 10mm deeper than the normal cap, the top section is about 10mm larger in diameter with 3 hold down screws and fits OVER the lower body instead of on top of the lower body. Also the wire exit hood is turned a bit more clockwise looking from the top down. There is a Bosch number inside ZZVS73Z11
Rob
69rulz Samba Member
Joined: June 07, 2009 Posts: 867 Location: On a trip on my couch
Posted: Thu Jun 14, 2012 6:15 pm Post subject: |
Will these fit a later model distributor like an 034? _________________ Id rather die on my feet than live a life on my knees Right turn clyde |
Glenn Mr. 010
Posted: Thu Jun 14, 2012 6:20 pm Post subject: |
69rulz wrote: |
Will these fit a later model distributor like an 034? |
No. _________________ Glenn
Member #1009
#BlueSquare |
FlexMyFoil 58' Samba Member
Joined: July 09, 2010 Posts: 47 Location: West Sussex, UK
Posted: Sun Sep 23, 2012 5:25 am Post subject: |
Will this style flat BOSCH distributor cap fit a 019 ? _________________ ---- ---- ---- ---- ---- ---- ----
Bella 58' 1776 twin kadrons
Glenn Mr. 010
Posted: Mon Jul 21, 2014 10:36 pm Post subject: |
Actually that taller flat cap will work on the VJ 4 BR 8, 019, VJ 4 BR 25, 010's. They were stock for Goliath and possibly others. I have a Goliath VJ 4 BR 16 that uses the tall cap as stock
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=80 _________________ Roads Scholar &
Posted: Tue Jul 22, 2014 5:53 am Post subject: |
Posted: Sun Jul 05, 2020 12:21 pm Post subject: |
Yes,
The hooded exit for the plug wires is a bit cockeyed but it does fit/work fine. _________________ Roads Scholar &
