Ryanqzqz Samba Member
Joined: September 08, 2012 Posts: 166 Location: Springfield, mo
Posted: Mon Jul 21, 2014 8:17 pm Post subject: '71 Super 1600DP Won't start when humid/wet |
160f0DP with 34PICT3 carb and a Pertronix Flamethrower SVDA dizzy. I've had repeated issues with starting in moist weather or after a wash... She'll crank, blow plenty of fuel but not catch. The other morning I ran into the same problem after a night of hard, heavy rain... I started checking everything, pulled center wire off the top of the dizzy to check spark and got good spark off the fan shroud, plugged it back in, no go. Unplugged again to check inside the center terminal just in case water or corrosion in it, and my wife happened to crank, I got spark between the center wire and the cap and it started!!! I figured I had a cap issue or wire issue. I switched for a known good center wire and a new cap off a NIB dizzy I have.... no change... weird.
So at work, I bought new wires, coil, rotor and seemed okay, but of course things dried up over the course of the 90+ degree day
This morning it was very foggy and humid, not even wet on the back of the bug, not wet on the cap, or shroud, but same issue, no start unless there was a gap between the center coil wire and the cap...... It would catch and if I would immediately plug back in, would die. I let it run for about 60 seconds, plugged in the wire, and ran fine. Turned it off and restarted, again, fine....
What in the world have I got going on???? I'm suspecting maybe the electronics in the Pertronix spark sprinkler are going out??? But not sure. Hoping someone has had this before because google is pulling me up all sorts of "no start when wet" stuff but nothing like this. _________________ - '71 Super Beetle, Cal look
- '73 Std. Beetle, donor car. |
Posted: Wed Jul 23, 2014 7:11 pm Post subject: |
Well. I suppose I'll try a new dizzy and see what happens. I should be able to get one around here somewhere. _________________ - '71 Super Beetle, Cal look
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Wed Jul 23, 2014 8:31 pm Post subject: Re: '71 Super 1600DP Won't start when humid/wet |
Ryanqzqz wrote: |
160f0DP with 34PICT3 carb and a Pertronix Flamethrower SVDA dizzy. |
It's pointless to convert to pointless. I'd point towards going back to points.
I'd make sure that the top of my distributor cap and the coil working end were REALLY clean, and that no wires are near any grounds or wires.
Try cranking/running the engine in the dark, and see if you see any sparks jumping. You'll be less tired if you do that in neutral so you don't have to run after the VW. Then mist a little water over the engine and look for sparks jumping. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Wed Jul 23, 2014 9:22 pm Post subject: |
When it does this spray the cap/wires with a good shot of WD40.
You have a shorting problem being caused by moisture.
WD40 means water dispersal formula 40. _________________ Good Luck
Al |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Wed Jul 23, 2014 9:41 pm Post subject: |
Plug wires. Old school American car fix is to wet a rag with kerosine and pull the plug wires through it. The solvent draws the water out of the tiny cracks and then evaporates.
Or you could fix it right and replace them if it failed in the driveway at home. |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Wed Jul 23, 2014 11:58 pm Post subject: |
ach60 wrote: |
WD40 means water dispersal formula 40. |
Exactly right. But AFTER the WD40 does it's job and the car runs, you need to use a paper towel etc to clean all the WD40 off the distributor cap and the wire end plugs. WD40 slowly dries to s sticky film (it's mostly kerosine with peanut oil), and the sticky residue will attract dirt and make new tracks for sparks to jump.
Also clean up the INSIDE of the distributor cap - a trace of moisture in there can cause sparks jumping which you can't see. _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Thu Jul 24, 2014 1:00 am Post subject: |
If this is a common occurrence you might look at a urethane waterproofing kit for your distributor & coil to keep the water out.
https://www.doghouserepair.com/store/item/6768/946...hane-empi/ _________________ AshMan40
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Thu Jul 24, 2014 8:01 am Post subject: |
Next time this happens, liberally pour rubbing alcohol into the cap, wipe it out, and let it dry. This will usually cure a moisture-related hard start, at least temporarily. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Thu Jul 24, 2014 10:11 am Post subject: |
Coil, wires, dist cap, rotor, and electrical terminals going to the coil from the wiring harness were all less than a day old the last time it did it. I tried wd40 the first time around to no avail.
Cusser I have a VW06 Rick Porter dizzy 009 clone I can try next time there's rain forecasted.... I also have a Vw10 on order. _________________ - '71 Super Beetle, Cal look
Posted: Mon Jul 28, 2014 8:57 pm Post subject: |
Update. Got my dual carbs in. Changed the dizzy out for that vw10 and got everything setup. Guess what... It rained this morning... And i'm running without a deck lid right now... And she started no problem _________________ - '71 Super Beetle, Cal look
jamesdagg Samba Member
Joined: August 18, 2007 Posts: 3364 Location: B.C.Canada
Posted: Tue Jul 29, 2014 5:49 am Post subject: |
Did you put the electronic ignition in the new distributor? If not maybe that was the problem.
Jim _________________ '72 FI Westy
'71 Super rear inside defrost vents no longer available |
