Luftgekült Samba Member
Joined: December 30, 2007 Posts: 388 Location: Canary Islands, Spain
Posted: Thu Jul 24, 2014 10:02 am Post subject: Superbeetle broken sway bar |
Hi
Let's start saying that my sb has standard suspension except for shorter springs (-5cm). Rubber stops were removed.
A couple of days ago the sway bar broke where it attaches to the arm. I was lucky as I was drinving like 10kmh but only 5 minutes before I was on the hiway. I prefer not thinking what could have happen if it broke at speed, since unlike other cars, in the sb the bar holds the wheel in place.
I know that there are sway bars for lowered cars, but my thinking is that they bring the wheel to its correct camber but never heard that not using it could lead to a broken bar.
My question is if you think that lowering the car put so much stress in the bar that it may broke or if it is just a age/fatigue issue?
Although there are a lot of lowered sb, I've never heard of a broken bar before.
Thanks!![/img] _________________ '71 VW 1302 1300cc in progress....
'72 VW 1302S 2109cc
'84 Passat Variant GL 1.6TD |
Jeff_Birt Samba Member
Joined: June 06, 2012 Posts: 315 Location: Rolla MO, United States
Posted: Thu Jul 24, 2014 11:27 am Post subject: |
What is the purpose of the rubber stops? To keep the suspension from moving too far and making sudden 'hard' stops. You removed them and allowed the suspension to move further and hit harder than it was designed to do consequently things broke.
Since all the parts of a suspension are designed to work together it is almost impossible to alter the geometry of one and not alter everything else. |
Posted: Thu Jul 24, 2014 1:26 pm Post subject: |
If I left the ribber stops the car sit on them
However, I've never felt the suspension bottomed _________________ '71 VW 1302 1300cc in progress....
'72 VW 1302S 2109cc
mountainkowboy Samba Member
Posted: Thu Jul 24, 2014 4:51 pm Post subject: |
Luftgekült wrote: |
However, I've never felt the suspension bottomed |
There was nothing to bottom on, the aftermarket bars are designed to correct the geometry for a lowered car. _________________ Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater" |
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Thu Jul 24, 2014 9:09 pm Post subject: |
It is a spring and they do fatigue eventually, much worse when things get rusty.
Rust pits=stress risers
Not sure what should be done to prevent rust there, but seems like an important issue |
