14platoon Samba Member
Joined: October 13, 2013 Posts: 444 Location: United Kingdom
Posted: Mon Jul 21, 2014 10:00 am Post subject: Creaking suspension |
I have a 1978 cabriolet beetle
My suspension is very creaky. The ride is good and appears to have a lot of recent parts. Over bumps etc the suspension creaks LOUDLY!
I have sprayed the rubber bushes with silicone spray but still she creaks. The noise appears to be coming from the diagonal arm area on both rear sides. I have sprayed these to no avail. Any suggestions?
I don't think parts need replacing as they appear to be good. |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Mon Jul 21, 2014 2:08 pm Post subject: |
probably those rear torsion arm bushings on each side.
fun job to do.... _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Mon Jul 21, 2014 5:02 pm Post subject: |
Are they urethane bushings? |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Tue Jul 22, 2014 4:41 am Post subject: |
You can't run urethane and expect quiet. New rubber bushes with talcum will do the trick.
Mr Duncan is probably right, though. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Tue Jul 22, 2014 9:49 am Post subject: |
It's really creaky!!!
I take it the talcum powder doesn't work on bushes that ARENT brand new? If not what is the best way to quiet the torsion bar bushes down?
Thanks |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Tue Jul 22, 2014 10:35 am Post subject: |
I don't think you can really do anything about it without disassembling it. Once you're that far into it you might as well replace the torsion arm bushings and that's the time to use the talcum powder. The bushings aren't all that expensive, it's the labor to get to them. On my kit car the person that built it didn't replace them on the worn out chassis before mounting the body. Now the only way to replace them is to remove the body. Fortunately the factory made sure it's not as hard to do on a stock bodied Type I. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Tue Jul 22, 2014 10:50 am Post subject: |
I have had some success using silicone grease, and using a thin grease needle to get it back into the bushings. I did loosen the torsion bar cap plates, but did not take anything apart. Loosening them relaxed everything enough to get the needle in. |
Posted: Tue Jul 22, 2014 1:41 pm Post subject: |
Nice one thanks |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Tue Jul 22, 2014 2:30 pm Post subject: |
mine creaks after I've been driving in the rain.
I just stick the skinny tube from my Superlube in the housing and squirt the bushing, work the suspension, then let it sit, repeat if still squeaky.
the superlube sprays like oil but sets up as a grease when it flashes off. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Wed Jul 23, 2014 3:51 pm Post subject: |
Thanks I'll give that a try as well. |
Axitech Samba Member
Joined: August 31, 2011 Posts: 1265 Location: Bucks County, Pa
Posted: Wed Jul 23, 2014 3:55 pm Post subject: |
I used liberal amounts of Never Sieze the last time I adjusted them. No noise, and I need to go back in and firm it up a bit, so I'm hoping the NS will make it a much easier job. Not that it was difficult in the first place. _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson |
Posted: Thu Jul 24, 2014 4:55 pm Post subject: |
I sprayed silicone spray practically everywhere, I haven't had a good run, but driving around the corner, I swear it creaked more! I'll try giving some of your ideas a go on my next set of days off. |
