lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Fri Jul 25, 2014 5:37 am Post subject: Fuel pick up tube |
Was sitting and thinking [bad thing for me to do]about the gas tank angle and how to make use of all the gas.WhatI am thinking of doing is adding a peice of fuel line to to the tube inside of tank and routing it to the low part of the tank and maybe securing it with a magnet.Anyone ever do this and what do you all think. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Jul 25, 2014 9:24 am Post subject: |
Might be just easier to add new permanent outlet at lowest point in tank.... Rubber tubing may deteriorate in time, magnet may shift and you end up with end of tube at highest point in tank.... Not my concept of a fix....
LeeVW Samba Member
Posted: Fri Jul 25, 2014 1:15 pm Post subject: |
Ditto what Dale said. I had thought about doing something like that after I ran out of gas with a gallon or so still in the tank, but the people on the forums convinced me not to. Knowing my luck, the thing would fail at the worst possible time.
I ended up cutting the inlet pipe so that it doesn't extend up into the tank very far like it did before. The reason for it sticking up is so the crud that builds up at the lowest point of the tank doesn't block the inlet. Since the inlet is no longer at the lowest point in the tank due to the angle, this is not an issue anymore. I still use the stock screen inside the tank along with a metal inline filter under the tank. I also carry 5 extra gallons of gas on those long trips.
Lee |
