kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Fri Jul 25, 2014 7:48 am Post subject: Steering columns |
Is one of these a better one to start with? I believe the one on the left is from a 71 auto vert and the one on the left from a 69 manual coupe. The wiring on the 71 has more wires and seems to be in slightly better shape. Any opinions?
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Fri Jul 25, 2014 2:29 pm Post subject: |
You can put that lock column from the '69 onto the steering shaft and tube from that 71. I like the longer lock column myself, and how the lock cylinder sits flush with the column. _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
swhitcomb Samba Member
Joined: November 05, 2003 Posts: 5673 Location: Inwood WV
Posted: Fri Jul 25, 2014 3:25 pm Post subject: |
The only turn signal switches available for 71s anymore are complete junk. I'd use the one from the 69. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
kman Samba Member
Posted: Wed Aug 06, 2014 2:04 pm Post subject: |
I had to make one switch out of two. The 71 one had a bunch of burnt and spliced wires in the column. The 69 had broken plastic pieces, so I stole the plastic pieces and spring from the 71 and put them in the 69. I kept the 71 column switch and key because the wires were much better and the key was a vw one.
I hope it works.
