greendevil332 Samba Member
Joined: April 05, 2014 Posts: 4 Location: Santa Cruz, CA
Posted: Fri Jul 25, 2014 2:03 pm Post subject: 64 Crew Cab running weird |
What's up thesamba, i'm having a problem with my '64 transporter crew cab. Long story short, I cleaned both the carbs (it has twin solex carbs) and put them back in, but now the truck doesn't sound right. It runs real rough, almost as though it's not running on all cylinders although i'm not sure. I'm also noticing an unusual amount of bluish smoke (which does not smell like gas, it just has a burnt smell). The weirdest thing, though, is that when you give it gas, the RPMs stay high for a couple seconds and then gradually return to idle. It's not a problem with the throttle linkage, because just by moving it with my hand while it's running I give it gas and then quickly move it back to idle, but the RPMs still lag and stay high for a couple seconds.
Any tips are appreciated also if you guys like i can record a video. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7045 Location: Lawrenceville, Ga
Posted: Fri Jul 25, 2014 2:33 pm Post subject: |
love videos! puppies, kittens, buses, you name it _________________ regards
Uli
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Sat Jul 26, 2014 4:22 pm Post subject: |
EDragnDean wrote: |
Had a same similar issue. One of your carbs isn't getting fuel. In my case, it was a stuck needle valve. To trouble shoot, pull a spark plug wire with the engine running. Dies, then that cylinder was getting fuel. No difference is the side you need to trouble shoot the carb on. |
I wouldn't advise pulling a plug out with the engine running. But, I knew what you meant. And use rubber gloves or insulated pliers. Those 24,000 volts tend to tingle a bit.
On the video it sounds like an exhaust leak. Did it sound like that before you worked on it? Are the wires on the spark plug ends fully engaged? _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Daddybus Samba Member
Posted: Sat Jul 26, 2014 5:24 pm Post subject: |
Check valve adjustment.
Check timing.
Sync carbs. |
joe cool Samba Member
Joined: August 20, 2006 Posts: 1259 Location: Yolo County CA
Posted: Sat Jul 26, 2014 5:44 pm Post subject: |
maybe look at your accelerator pumps for that sustained high rev issue. idle doesn't sound so smooth either. i would pull plugs and look for vacuum leaks to narrow the idle thing down. |
