Anchor points Cut them off?
Miaghia
Miaghia is offline
PostPosted: Mon Aug 04, 2014 2:49 pm    Post subject: Anchor points Cut them off? Reply with quote
When you update the interior with new carpet, should the metal button anchor points for the old carpetat be ground off flush?? These things seem useless and dumb under a new carpet kit!!
Thanks for comments and guidance
Mike
Miaghia
Miaghia is offline
PostPosted: Mon Aug 04, 2014 2:51 pm    Post subject: Reply with quote
Meant to say carpet / mat
jwold
jwold is offline
PostPosted: Mon Aug 04, 2014 3:39 pm    Post subject: Reply with quote
What if you wish to add rubber mats to protect the carpet later?
Miaghia
Miaghia is offline
PostPosted: Mon Aug 04, 2014 4:20 pm    Post subject: Reply with quote
I don't foresee mats that would fasten to these. Mainly because I would have to cut a big button hole in my brand new carpet. I have not see a single carpet install pic in the gallery that has them poking thru. Looking for someone who has installed new carpet to just confirm that they cut the useless things off. I guess I could punch circles out of the carpet padding and just span over the top of the buttons. Just don't know why I would ever want or need them.
retrowagen
retrowagen is offline
PostPosted: Mon Aug 04, 2014 4:28 pm    Post subject: Reply with quote
The great thing about having mats instead of permanent carpets is that they can be removed to dry things out more quickly and easier, when the KG leaks. Notice I said "when," not "if?" KG's are like submarines and dams: they all leak, and if they didn't, there would be a problem! Laughing
David Ruby
President, Karmann-Ghia World Club
c21darrel
c21darrel is offline
PostPosted: Mon Aug 04, 2014 4:49 pm    Post subject: Reply with quote
They are for rubber mats not carpet. Leave them, a future owner will be happy you did. Carpet goes under.
GhiaBuild
1967 DC build
Miaghia
Miaghia is offline
PostPosted: Mon Aug 04, 2014 4:50 pm    Post subject: Reply with quote
Where can I buy these mats? How big of a hole do I cut thru the carpet?
c21darrel
PostPosted: Mon Aug 04, 2014 5:06 pm    Post subject: Reply with quote
Samba member Lemke makes them.
http://www.thesamba.com/vw/forum/viewtopic.php?t=152358&start=40
GhiaBuild
1967 DC build
Miaghia
Miaghia is offline
PostPosted: Mon Aug 04, 2014 5:09 pm    Post subject: Reply with quote
I have read about lemke and how you pay and never get any product. Not too excited about that.
lonotch
Samba Padrino
lonotch is offline
PostPosted: Mon Aug 04, 2014 5:23 pm    Post subject: Reply with quote
Put some padding with the hole cut for the mat then put the carpet on top of the padding so the carpet lays flush, no need to put a hole in the carpet and you get to keep the pins for later use if needed.
It's not about the window, it's about the people.
German Folks
Miaghia
Miaghia is offline
PostPosted: Mon Aug 04, 2014 5:25 pm    Post subject: Reply with quote
It is decided. That is exactly what I will do. Thanks
