jayster Samba Member
Posted: Sun Aug 10, 2014 11:00 am Post subject: 56 oval clutch slipping after fitting new clutch |
Have a 56 oval which has had all new clutch fitted.
Problem now is that when i give gas it will slip Like it is struggling to cope with the revs.
I Have been told that it is probaly a adjustment on the clutchwaire.?
After having all new clutch parts it cant be that i need another clutch?Any help would greatfull
Dave Byron Samba Member
Joined: June 04, 2012 Posts: 184 Location: Grays Essex UK
Posted: Sun Aug 10, 2014 11:12 am Post subject: |
Sounds like it's an adjustment issue maybe the cable is to tight meaning the clutch can't fully engage try backing the adjuster off. |
Posted: Sun Aug 10, 2014 11:18 am Post subject: |
Ok is this easy to do Never had a 56 before..in fant Never had to adjustment the clutch before. |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sun Aug 10, 2014 4:48 pm Post subject: |
loosen the adjusting nuts (or wing nut) on the clutch cable until there's about 1/2" or so free play at the clutch pedal. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Sun Aug 10, 2014 10:20 pm Post subject: |
Joey wrote: |
loosen the adjusting nuts (or wing nut) on the clutch cable until there's about 1/2" or so free play at the clutch pedal. |
Posted: Sun Aug 10, 2014 10:21 pm Post subject: |
Joey wrote: |
just checked my clutch pedal and there is no free play what so ever..it is really hard. |
