bdub475 Samba Member
Joined: April 05, 2009 Posts: 577 Location: Los Lunas, New Mexico
Posted: Sun Aug 10, 2014 3:13 pm Post subject: 40hp wrist pin height |
Does anyone know the pin height on stock 40hp pistons? I'm trying to figure out what the distance from main center to the top of the piston.
Half stroke 32mm + Rod length 130mm + Pin height ?
I plan to build a 40hp stroker using a 69mm crank and modified 40hp rods. I'm trying to find 77mm or 83mm pistons with the correct pin size and height to keep the engine close to stock width. |
avus Samba Member
Joined: November 11, 2005 Posts: 268 Location: Drain, Oregon
Posted: Mon Aug 11, 2014 7:51 pm Post subject: Re: 40hp wrist pin height |
bdub475 wrote: |
Stroke increase is 5mm==2.5mm per cylinder shim. To me this seems inconsequencial. The tin still fits well, and the exhaust and intake can be bent to fit. Use 1600 pushrods, and you're home. |
Posted: Mon Aug 11, 2014 8:07 pm Post subject: |
Thanks Avus. Thats most likely what I will end up doing. I just wanted to make sure there isn't a better of the shelf piston that would work. |
modok Samba Member
Posted: Mon Aug 11, 2014 10:32 pm Post subject: |
should be 39mm |
pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Posted: Mon Aug 11, 2014 10:52 pm Post subject: |
I have some NOS 83.5mm pistons, 20mm pin and good 83.5mm (1500) cylinders that I was going to use on a 36hp build...
change of direction means I am using 80mm to stay in 1400cc engine class... so they are for sale for the right money. Pm me if you like...
alternatively I have a note somewhere of some Japanese pistons that are 77mm with 22mm pin and a lower pin height which would get you closer to stock width... I will have a rummage.
