deadwesty Samba Member
Posted: Mon Oct 14, 2013 11:42 am Post subject: Gas burners - Repop offset |
A stupid teenager girl in a F350 rear ened into my Jetta TDI......So I have to use my 67 bug even more now. I am going to make it a safer daily driver on freeways, etc. I will install CB's disc brake kit with drop spindles and will run repop gas burners and real gas burners later down the road.
My question is: what is the off set on those repop gas burners? I recall Og ones have off set of 42mm? I am kind of new to those stuff - Is it "more tuck" or more "outside" compare to stock set up of 36mm??
I cant stomach the look of bugs lowered with stock rims/width beam. I dont want to achieve that look with 2 inch narrow beam from CB? Cuz the disc brakes will gain 3/8 inch on each sides?? I would like for the gas burners to be Slightly more tucked compare to where the stock wheels are on the stock set up - not too much (dont want trike style handling).
As for rear, I think I will be fine? Long axles seemed to works well with OG gas burners based on other comments. What about Repop?
Any info or pics will be appreciated. Educate me on lowering stuff, my first one. I am about to start ordering/buying stuff. _________________ Instagram- @vwwanderers
1986 westy syncro
1990 tin top syncro |
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Mon Oct 14, 2013 4:19 pm Post subject: |
If your 67 has a wide 5 bolt pattern I think you're out of luck.
Repo gas burners are available in 4x130, 5x130 and 5x112.
5.5 x 15 repo GB has a 4 inch backspacing, which works out to an offset of 19 mm. |
Posted: Mon Oct 14, 2013 5:12 pm Post subject: |
The cb disc brakes kit comes in Porsche pattern which will work with gas burners.
As for rear, I will drill drum into that pattern.
19mm? 4 inch adapter? Am lost here? Can u explain more?
Thanks _________________ Instagram- @vwwanderers
1986 westy syncro
Posted: Tue Oct 15, 2013 12:46 pm Post subject: |
Thanks! I get a better picture now. So what is the final off set for repop gas burners? 43mm just like OG ones or? compare to stock at 36mm (correct me if i got the number wrong).
If thats the case, gas burners - 43mm, stock - 36mm, that mean the gas burners will tuck more than stock correct?
Thanks again. _________________ Instagram- @vwwanderers
1986 westy syncro
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue Oct 15, 2013 2:27 pm Post subject: |
No 43mm sticks out further than 36mm, but 7mm=1/4" is barely visible anyway. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Tue Oct 15, 2013 3:21 pm Post subject: |
Ok! So with 3/8 inch gain on each sides due to disc brakes Plus around 7mm more from the wheels. With 2 inch narrow beam, the end result will still be slightly narrowed than the stock set up.....
I think that works! Hope I will be ok with 2inch beam.
Thanks guys!! _________________ Instagram- @vwwanderers
1986 westy syncro
Posted: Tue Oct 15, 2013 4:30 pm Post subject: |
A 46mm ET is a flatter faced wheel, so the 36mm ET sticks out further now that I think about it further. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Wed Oct 16, 2013 7:31 am Post subject: |
Mike Fisher wrote: |
A 46mm ET is a flatter faced wheel, so the 36mm ET sticks out further now that I think about it further. |
Ur giving me some head aches.....
If thats case, then 2 inch is plenty for me.
Thats if the repop wheels are at 43mm just like the originals, which havent been confirmed. Cip1 website said nothing about the offset.
Either way, I will begin my shop spree! Sorry - my lady, ur clothes gotta wait! _________________ Instagram- @vwwanderers
1986 westy syncro
Posted: Wed Oct 16, 2013 8:26 am Post subject: |
I've had 34,41 & 46ET stock steel wheels on my squarebacks. They all fit fine, but the 34ET looked the best because they were more dished. When you have the new wheels,brakes,spindles then you can do your measuring to determine the beam,stance,tires etc. You should mock it all up with the stock beam. _________________ https://imgur.com/user/FisherSquareback/posts
mlhsquared Samba Member
Joined: October 13, 2008 Posts: 1482 Location: Strasburg, VA
Posted: Wed Oct 16, 2013 9:18 am Post subject: |
Cool! So correct me if I misread, but seem those repop 5x130 has off set of 45mm. which is 2mm more "tuck" than originals correct?
I thought CIP1 is the only place where I could buy those wheels. Guess I am wrong? Are those empi wheels different from Cip1 or does they comes from the same manufacturer? If different, which one is better?
Mike - I am really trying to avoid the longer route, mock, etc. Especially when we could do the math route, offset, etc based on what we know and from others' experience. I get what you mean via dished look, but thats not what gas burners are supposed to be. More flat on outside is just what I wanted. _________________ Instagram- @vwwanderers
1986 westy syncro
Posted: Wed Oct 16, 2013 10:43 am Post subject: |
Cip1's gas burners have a 4" backspace, which works out to roughly a 20mm offset. Since the Empi's have a 45 mm offset I don't think Cip1's burners are Empi.
The 45mm offset is the way to go, and since the wheel has a flat surface it won't matter, looks wise. |
Posted: Wed Oct 16, 2013 10:48 am Post subject: |
911pickup wrote: |
Good to know, definitely would want the 45mm offset instead of 20mm!
One more thing, how can i tell apart between EMPI and CIP1 wheels? There is a set of used repop wheels locally. That will save me some bucks but wanted to make sure they are EMPI? If am to measure the offset, where do i measure to confirm where they are from? If anyone has empi wheels on hand who can share the differences??
Thanks. _________________ Instagram- @vwwanderers
1986 westy syncro
Posted: Thu Oct 17, 2013 9:22 am Post subject: |
The offset (example ET45) should be stamped on the back of the wheel. |
Posted: Thu Oct 17, 2013 9:52 am Post subject: |
Great! thats what i need to know. So Cip1 wheels should show something else - like 20mm or 4inch back spacing.....
Many thanks. _________________ Instagram- @vwwanderers
1986 westy syncro
Posted: Thu Oct 17, 2013 1:31 pm Post subject: |
They are sold under the Gasser name, which is EMPI's name for them. Here's one place that has them:
http://www.socalautoparts.com/product_info.php/emp...ap-p-16984
Google EMPI Gasser 5 x 130 and you should find more. Anywhere that carries EMPI should be able to get them for you.
As for fit, I have a '67 Ghia, which is notorious for the difficulty fitting wheels on the back. I fitted a set of the 2-liter repops and have no issues. The Gassers in 5 x 130 have more offset and backspacing, so I don't think they will give you any problems. It would be nice, though, to hear from someone else that's running these on a long axle car.
The best way to measure the backspace on those used wheels is to take a straight edge (longer than the wheels is across) and a tape measure. Turn the wheel over and lay the straight edge across the width of the wheel as close to center line as possible. Now with the tape measure, measure from the bottom of the straight edge to the flat back of the bolt hole surface. This should be your backspacing. If it's about 5", you should be fine. Best of luck in your endeavors. |
vdubjim Samba Member
Posted: Tue Jul 29, 2014 6:36 pm Post subject: |
sorry to bump an old topic, but this seemed like the best place vs. new topic.
I got a set of empi gasser gasburners cheap. And new drilled 4 lug drums. had the snout machined off fits well…..BUT with 195/65 they rub the spring plate, not locking uo the wheel but enough for damage.
So im debating long axle, instead of spacers, BUT is long axle too long? |
Posted: Wed Jul 30, 2014 9:28 am Post subject: |
I used spacers & longer lug bolts on the rear of my square to get my 2.0 liter wheels dust caps to fit. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Mon Aug 18, 2014 7:07 pm Post subject: |
And then there was mike....
Yea ok.
My gasburner dilemma I had to solve myself.
Short axle drilled drum, rubs spring plate, short axle with wheel adapter, good. Empi gasser wheel. |
