RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Mon Feb 06, 2006 1:03 am Post subject: 043 VW head casting/valve size? |
What size valves come standard on the VW 043 head? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Mon Feb 06, 2006 3:54 am Post subject: |
I think 40x35 is the "standard" valve size for them. _________________ Glenn
Member #1009
#BlueSquare |
steel buggin Samba Member
Joined: March 24, 2003 Posts: 415 Location: Arcadia,Ca
Posted: Mon Feb 06, 2006 8:19 am Post subject: |
The 043 was a F.I head and I think the valve's where 34 x 32 which were even smaler then a carb engine. But now in day you may find 043 casting with all type's of valve size's check these 043 head out.
https://www.thesamba.com/vw/classifieds/pix/1039559.jpg |
Glenn Mr. 010
Posted: Mon Feb 06, 2006 8:23 am Post subject: |
THANKS |
millerje78 Samba Amishman
Joined: October 16, 2005 Posts: 2445 Location: Holmes County, Ohio
Posted: Mon Feb 06, 2006 9:53 am Post subject: |
you could LIVE in those ports, steelbuggin.
-jesse _________________ always seeking a better way
my 73 standard project
do your research, consult with experts, and buy quality parts. you won't be sorry |
Posted: Mon Feb 06, 2006 12:43 pm Post subject: Re: 043 VW head casting/valve size? |
33 X 30, 35 X 32, 40 X 35, and 42 X 37.5 have all been used in that head. There is no "stock" size, you must measure them.
John
Aircooled.Net Inc. |
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2926 Location: Germany
Posted: Mon Aug 18, 2014 4:22 pm Post subject: Re: 043 VW head casting/valve size? |
[email protected] wrote: |
John
Hi folks, I've bare 043 heads with no seats, just the seat bores, and I'm having a hard time trying to source a 30mm valve seat and a 30mm valve. But it just occurred to me that I've no idea if that's definitely what I need, or maybe it's possible for me to ram a 32mm in there, cos it depends on the OD, ID and the valve seating surface I'd assume. So how the fu*k does one work that out? Like if it was a 30mm exhaust valve, what would the OD, ID of the seat need to be? And what'd the valve sealing surface be? 1mm or wha? And I know everyone will say, send it to a machine shop, and maybe I will, but what magical knowledge do they have to help them choose? Anyone able to guide me? _________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Mon Aug 18, 2014 4:41 pm Post subject: |
Sure. The seat OD should be about 1mm larger than the valve, there is some wiggle room to go either way.
In a OE VW head the seats are peened over making them appear smaller from the outside.
you can fit the seats to the head, or fit the head to the seats, but of course this requires a VGS machine and a lathe, which I'm guessing you don't have.
Also, most valves can be made smaller. Can't make em bigger tho |
Posted: Wed Aug 20, 2014 2:13 pm Post subject: |
Thanks Modok. I don't have a lathe or VGS machine. Thanks for the info and tips, they may give me some latitude of approach once I measure up the bores again... _________________ 1973 1303 with AB-motor - sporadic
Posted: Wed Aug 20, 2014 2:17 pm Post subject: Re: 043 VW head casting/valve size? |
The first thing they do is measure them, which you seem to be averse to. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Wed Aug 20, 2014 3:10 pm Post subject: Re: 043 VW head casting/valve size? |
The first thing they do is measure them, which you seem to be averse to. |
A hasty conclusion and a smartass answer, John. I did measure them some time back, that's why I said I was trying to find a 30mm valve. Put some lotion on it. _________________ 1973 1303 with AB-motor - sporadic
