JoshG Samba Member
Joined: March 16, 2005 Posts: 189 Location: Boston, MA
Posted: Fri Aug 22, 2014 1:26 pm Post subject: Shock extenders |
I would very much like to run Koni shocks with Go Westy Zero lift springs. However, as I understand it, the Konis are basically too short and will top out over large bumps when fully extended.
I seem to recall some discussion awhile back about the availability of extenders (not sure that is the technically correct way to describe them but that seems to capture what they do).
Does anyone know if these are commercially available?
Does anyone (gulp) have an opinion as to whether this is a safe? |
ShootingFish Samba Member
Joined: July 25, 2010 Posts: 330 Location: Portland, OR
Posted: Fri Aug 22, 2014 1:50 pm Post subject: |
I will tell you now that the GW Zero Lift Spring will lift your van. I went up about 1" in ride height when we did all of the work this spring. They ride great, but the van certainly sits higher than it was before.
I went with the new Bilstien HD Sport shocks on our Full Westy and I am very pleased. _________________ SF
Props aren't just for boats....
'88 2WD ALH-TDI Westy
'90 Syncro 16 Doka |
JoshG Samba Member
Posted: Fri Aug 22, 2014 2:27 pm Post subject: |
ShootingFish wrote: |
I went with the new Bilstien HD Sport shocks on our Full Westy and I am very pleased. |
Good to hear!
I may end up going that route if there is no way use Konis. |
rcook52459 Samba Member
Joined: August 24, 2011 Posts: 492 Location: PORTLAND ORE
Posted: Fri Aug 22, 2014 5:21 pm Post subject: |
my sits high and standard shocks topped out over bumps.put mr. gaskets shock extenders on,then they bottom over bumps.had to rethread them to metric which was no big deal.they were tight on the shocks.here's what I did put 1979 ford f-150 shocks on the front.had to pur 3/4in spacers on each side of bottom of shock.they are 2in longer and work great.then for the rear I used chev astro van shocks straight bolt on.they are 2in longer to. _________________ 85 westy tiico conversion.auto trans triumph TR250 1980 Suzuki GS1000l |
