165/50/15 on stock adjustable beam
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
ClassicBugFan
ClassicBugFan is offline
PostPosted: Sat Mar 09, 2013 10:01 pm    Post subject: 165/50/15 on stock adjustable beam Reply with quote
I'm looking for pics of bugs with a stock width adjustable beam, on 165/50/15's i read alot of posts and people say they dont work on a beetle. I currently have 195/50/15's on the front my bug and and they are rubbing a bit when i adjust it halfway down (in the pic) i am planning to buy the 165's but i first wanna see how they look on a slammed or semi slammed bug.
Aircooled Volkswagen Forever
slalombuggy
slalombuggy is offline
PostPosted: Sun Mar 10, 2013 8:00 am    Post subject: Reply with quote
The tires will be about 1.5 inches shorter than you 195s and about 1.5 inches narrower. they are very short and should fit under any car. I'm running the 45 series on the front of my buggy and now they are going on my 57 with a modified front end that has much smaller wheel openings and narrower fenders. I'm running a 4" narrowed beam with disk brakes so the wheels sit in about 1.5 inches on each side.
On my buggy I can run the front beam 1 inch off the ground and there's still lots of clearance on the fenders at the top.
brad
ClassicBugFan
PostPosted: Sun Mar 10, 2013 8:13 am    Post subject: Reply with quote
It looks awesome on the buggy... will the 165/50's rub alot if i slam it? cause the whole point of getting the tires are that i dont want to narrow it, but i want to slam it with stock beam width and narrow tires i dont mind a little rubbing but not too much rubbing
Attorney Isaiah Loophole
Attorney Isaiah Loophole is offline
PostPosted: Sun Mar 10, 2013 7:10 pm    Post subject: Reply with quote
This is a buddys car and it is a stock width adjustable beam with 165/50/15s
Bryce
Georgia Dubs
61 Beetle "Old Blue"
62 Beetle
64 Beetle "Pat"
ClassicBugFan
PostPosted: Mon Mar 11, 2013 9:56 am    Post subject: Reply with quote
Very Happy AWESOME BUG Very Happy
is there any rubbing on the fenders? and how low can you go with those tires?
slalombuggy
PostPosted: Tue Mar 12, 2013 6:55 am    Post subject: Reply with quote
The tires are TINY you shouldn't have any problems rubbing with your car slammed. I think the 165/50s are just over 21" tall. Be prepared for your tire guy to hate you though. They are an absolute cow to mount. The sidewalls are very stiff, the tires are very small and getting them off a rim is a real workout if you need them taken off to get patched.
brad
PostPosted: Thu Mar 14, 2013 9:21 am    Post subject: Reply with quote
Pm callahan to find out more about his car
Bryce
Georgia Dubs
62 Beetle
64 Beetle "Pat"
ClassicBugFan
PostPosted: Sun Mar 31, 2013 5:40 pm    Post subject: Reply with quote
So i decided to order the 165/50's this week, Laughing Now im waiting, i hope they get here by friday or saterday , cant wait to post pics when i get them
ClassicBugFan
PostPosted: Thu Apr 11, 2013 12:44 pm    Post subject: Reply with quote
Stock width beam, slammed on 165/50/15 Laughing
slalombuggy
PostPosted: Fri Apr 12, 2013 7:22 am    Post subject: Reply with quote
NICE!!!! Hope you have nice smooth roads.
brad
ClassicBugFan
PostPosted: Fri Apr 12, 2013 7:25 am    Post subject: Reply with quote
Very Happy Thanks.. The roads are fine, but the speedbumps and the cops are the problem
ClassicBugFan
PostPosted: Tue May 27, 2014 2:35 am    Post subject: Bumblebee Slammed Beetle Reply with quote
Bumping it up
Laughing
165/50/15's on 6j widened (inwards) steelies
195/50/15's on 8j widened steelies
Stock width adjustable beam
Custom Adjustable springplates
There is some slight rubbing on the headlights but will sort that out, other than that the car drives like a dream, no hard bumping and bottoming out on rough roads.
It can go much lower but i can't get into my yard Embarassed
zodlaw
zodlaw is offline
PostPosted: Tue Aug 26, 2014 8:15 am    Post subject: Reply with quote
what is your setup in the rear,you running 2 inner or outer splines?
68 build that had been sitting for 18yr in a garage.
http://www.thesamba.com/vw/forum/viewtopic.php?p=8119987#8119
Bagged 69 pile (SOLD)
http://www.thesamba.com/vw/forum/viewtopic.php?t=591100&start=0
ClassicBugFan
PostPosted: Wed Aug 27, 2014 3:22 am    Post subject: Reply with quote
Custom made notched adjustable springplates.. I adjust it with a 10mm allen key skrew Very Happy
Looks almost almost like the empi adjustables, just with longer skrew
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
